Stainless Targa Band restore
I have a 1972 911 with a few scratches and a ding in my stainless band. Any suggestions on where to send it? I'm in Reno. My fear is that someone will polish it too much and make look odd.
Old 02-16-2023, 08:59 PM
You probably want it brushed not polished.
Old 02-17-2023, 04:57 PM
That makes sense. Wonder who can brush it?
Old 02-17-2023, 08:13 PM
group911@aol.co's Avatar
You can. Scotch Bright and some lubricant- WD40 or other. You only do it in one direction which is long ways. It works with or without a sanding block.
Can't remember if I used black or red Scotch Bright.
Experiment with a couple to see which one gets the desired brush.
Thanks,
Bob
group911@aol.com
Old 02-17-2023, 08:56 PM
This is what you need. They make them in different grades of coarseness, so you’ll have to find the one that best matches the factory finish. You might have to remove the bar and try it in a hidden area, or start with the finest grade and work your way up to the one that’s a best match.
https://www.amazon.com/Bergeon-5444-B-Polishing-Finish-Polish/dp/B07Q7Q4KVQ
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 02-18-2023, 06:43 AM
Analog Air Cooled
Hotshot's Avatar
glass bead blast and clear cerakoe
86 Targa
91 964
13 6 SPD Cayenne
Old 02-18-2023, 07:33 AM
Looks like an overpriced scotch bright solution.
Thanks,
Bob
group911@aol.com
Old 02-18-2023, 09:09 AM
206 637 4071
Old 02-18-2023, 09:33 AM
Why would you bead blast a stainless steel targa bar and destroy it??
Old 02-18-2023, 12:48 PM
I’ve used Scotch-Brite and I’ve used the Bergeon bars to refinish brushed Rolex oyster bracelets, and the Bergeon bars give a much more even finish and are easier to use.
Old 02-18-2023, 04:55 PM
Analog Air Cooled
Hotshot's Avatar
To start the restoration process. I’m talking about a fine glass bead or say soda. Then polish and protect.
86 Targa
91 964
13 6 SPD Cayenne
Old 02-18-2023, 09:13 PM
Wangrande's Avatar
My 72 was DA sanded with 80 grit and buried in satin black to look newer. When I restored it I had nothing to lose. The circle swirl marks from the coarse grit sanding was horrible. Used an inline air sander through finer grits and brought it back to perfection. It's only a piece of metal. You really can't make it worse and will eventually get it done, It was very satisfying to rescue it.
72 T 3.2
Old 02-22-2023, 06:58 PM
'73 911 T Targa
Have you seen them polished? They look great.
Old 02-23-2023, 07:38 PM
