-   -   Problem identifying this part in the PET (http://forums.pelicanparts.com/porsche-911-technical-forum/1135301-problem-identifying-part-pet.html)
Hawkeye's-911T 02-21-2023 02:39 PM
Hello to All & Happy (Belated) Presidents Day to our American brothers & sisters
Could someone please provide me with a p/n for this part from the front fender(s) - L & R headlight harnesses for a 1970 911T. I require only the replacement gasket or its ident. number or part description (both sides) for this portion of the harness assembly.
http://forums.pelicanparts.com/uploa...1677017801.JPG
Headlight harness - general arrangement
http://forums.pelicanparts.com/uploa...1677018093.JPG
Unknown name for, and/or P/N mystery piece & its required gasket. Any help is most appreciated. I'll post this in the 911S registry also.
Thanks & Cheers
JB
Quicksilver 02-21-2023 02:54 PM
Sorry. PET only lists the left and right as "harness for headlamp".
- Left: 911.612.024.00
- Right: 901.612.047.00
David Inc. 02-22-2023 05:23 AM
You can always measure the gasket and replace it with general rubber weather stripping of similar size. Cut to length and superglue it into a circle.
Dpmulvan 02-22-2023 06:30 AM
Large o rings or some old vacuum cleaner belts, along with replacement belts for rock tumblers make good gaskets. Also McMaster Carr has solutions.
Hawkeye's-911T 02-22-2023 10:24 AM
So far, it appears the best & perhaps the only option is to fabricate a gasket from some suitable material. Thanks for your input guys - much appreciated.
Cheers
JB
