-   -   flywheel torque values problem (http://forums.pelicanparts.com/porsche-911-technical-forum/113553-flywheel-torque-values-problem.html)
fallonmi 06-04-2003 06:50 PM
I am putting my engine back together and am a little confused as to the correct torque value for the flywheel bolts. The engine is a 3.0 out of my '82 SC. Wayne, in your rebuild book, the paragraph on how to reattach the flywheel under the "crankcase" says 120 N*m. In the torque values table in the back of the book, it says 90 N*m. Any insight on which one is correct?
Thanks.
-Mike
Early_S_Man 06-04-2003 07:52 PM
90 Nm in the spec book for M10 flywheel bolts ...
yelcab1 06-04-2003 09:43 PM
With a little blue loctite
ChrisBennet 06-05-2003 03:47 AM
Loctite tip
Here's something from my archives:
Subject: Re: Threadlock on flywheel stretch bolts
Date: Sun, 21 Mar 1999 14:56:24 EST
X-Message-Number: 32
David,
Use Loctight red 271. bolt the flywheel with two opposing bolts to
the crank. Only then apply some 271 to a bolt and insert it and tighten.
Repeat for remainder of bolts including the initial two you started with.
Reason: if flywheel is not mated solid to the crank, some of the red will get
behind the flange and cause just enough of a miss match to loosen flywheel
after awhile.
Ten years ago at Daytona we lost two flywheels because of locktight
behind the flange. It took someone much smarter than I to point it out to me.
Never lost a flywheel after that.
Clay Dopkd
dopke/design Motorsports
