jphillips-998's Avatar
Please help! Alt. Shaft Pin Removal????
Hey all, in the middle of replacing my alternator...so far so good.
The good news is that I did not LOSE the shaft pin...the bad news is that I can't get it off the old alt. shaft! Any secrets?
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 06-05-2003, 08:37 AM
Dept store Quartermaster
lendaddy's Avatar
If you are talking about the woodruff key, then the PO probably loctited it. Just heat it up and it should come right off.
Cornpoppin' Pony Soldier
Old 06-05-2003, 08:49 AM
Somewhere in the Midwest
MotoSook's Avatar
Your new Alt should have come with a woodruff key, but heat and maybe a little force will get it out.
Old 06-05-2003, 08:53 AM
grab with sidecutters and lever it out, or use a hammer and punch inward on one end, which will roll it out of the slot enough to grab it better.
206 637 4071
Old 06-05-2003, 08:55 AM
Thank you gents.
The new (rebuilt) alt. did not come with the woodruff key. I will try the heat and beat method.
Jeff
'98 993 Cab
'91 944S2 Track Car
Old 06-05-2003, 08:59 AM
MotoSook's Avatar
If you bung it up or can't get it to come out..I have one you can have Jeff. Just a short drive into the country
Old 06-05-2003, 09:01 AM
thanks for the offer...it's a great day for a drive FINALLY!
On second thought, it is a great day for a drive to the CITY....
Jeff
'98 993 Cab
'91 944S2 Track Car
Old 06-05-2003, 09:05 AM
MotoSook's Avatar
..and over heat while I'm stuck on COngress or LSD..now way man.. I'll take the fields and cows unless I feel like some really good food and a stroll down Michigan after dinner.
Good luck wiht the Alt.
Old 06-05-2003, 09:08 AM
Senior Member
Jdub's Avatar
Woodruff keys can get lodged as you pull an object off a shaft. If you are having trouble, push the object back on the shaft as it was, spray copious amounts of WD-40, and gently move the object off. Keep working it this way until the object slips the shaft.
John, whose TR4 crankshaft pulley finally had to be cut off the crankshaft!
'78 Targa in Minerva Blue
Old 06-05-2003, 09:09 AM
