Momo collector
Removing the steering shaft lower bearing
Hey fellows,
as with most 911s, the steering wheel on my 911 (77) wobbles far too much. I have read all the instructions, what alternatives there are, the 928 sleeve and so on. I would like to remain original, however, have already bought the parts and started to disassemble everything. I have to say that I don't want to remove the whole unit, just change the steering rod and then the bearings.
this is how far i got: i got the steering rod out with a puller tool, also the upper bearing, which is always a lot of trouble. when i look inside the tube, i see a lot of dirt and the lower bearing can no longer be rotated either.
in plain text: I'm only missing the lower ball bearing. i've tried to knock it out from above, but i have the impression that it doesn't move at all. I've probably already destroyed my steering rod with it, the thread looks crooked and I can't get the nut on it anymore.
no matter, how do I get the ball bearing out - in the installed state? any ideas? Thanks very much!
Mads from https://www.patipatina.com
Old 03-04-2023, 05:51 AM
You need to remove the circlip
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-04-2023, 07:42 AM
Old 03-04-2023, 07:45 AM
There’s grooves inside the steering tube that have circlips you need to remove. 47 49.
Old 03-04-2023, 07:47 AM
I have a spare steering rod if you need one.
Old 03-04-2023, 07:52 AM
Momo collector
Wait a minute, there is a circlip holding that f*** bearing inside the tube?
Guess it's just too dirty to see that f*** b**** ;-))
Thank you so much!
And re the rod, how much you need for that? Trying to fix the thread first but if that doesn't work, yours would be an option!
Old 03-04-2023, 08:11 AM
Just pay shipping.
Old 03-04-2023, 08:19 AM
Momo collector
Awesome! I do that .. Send you a PM
Old 03-04-2023, 08:23 AM
Uncertifiable!!!
Uwon's Avatar
Yes, circlip is pressed against the inside of the tube and is really hard to see. The circlip has really small ear holes. A mirror and a spray can of brake fluid is likely your best friend. Also, remember that the are at least two lengths of steering tubes and upper shafts depending on the year. The ones in my ‘71 are longer than my ‘78 based RST.
Good luck.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-05-2023, 04:56 AM
Momo collector
Received a replacement from Dpmulvan - thanks again buddy! Improved the spline a bit, installed it, works excellent! Thank you so much for your support guys!
Old 03-11-2023, 11:29 PM
