1977 911 Electrical Question
My passenger side tail lights is completely out. I don't get any power at that location. The driver side light is perfectly fine. I went to the fuse panel and I see the number 8 fuse, which I think is for this light doesn't have power either.
Where does the power to this fuse come from the ignition switch?
Old 03-10-2023, 11:07 AM
PCA Member since 1988
Check the right front marker lights. If you don't have power to the right side fuse, that should be out too.
The power to the tail lights and side marker lights comes from the headlight switch.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-10-2023, 01:16 PM
