-   -   Smoke test no start issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1136047-smoke-test-no-start-issue.html)
David Inc. 03-07-2023 09:30 AM
The pop off might be leaking just because you're putting pressure behind it when normally it's under vacuum. I wouldn't worry about it unless it still fails to start with everything else okay.
PeteKz 03-07-2023 09:45 AM
=1 what David said. Well, have you tried to start it yet?
joe912/62 03-07-2023 10:09 AM
Here you go, thanks for everyone's help. I know it will take more tuning.
https://youtu.be/h-998cQ1qdc
pmax 03-07-2023 10:21 AM
^^^Nice
Originally Posted by joe912/62 (Post 11941033)
The only area that is leaking is the Pop off valve toilet seat.
I will put everything back on and see if it starts.
Check if it's leaking under the toilet seat cover or around the base.
If the latter, it's time to reseal.
ahh911 03-07-2023 10:24 AM
http://forums.pelicanparts.com/support/smileys/fles.gif
joe912/62 03-07-2023 11:16 AM
It looked like just around the seat, there's a big o-ring that the lid closes on. Don't know if they sell those seperatly that could be replaced.
PeteKz 03-07-2023 12:30 PM
Success!
I have a 25-year old pop off valve on mine. Haven't had any leak problems. If the O-ring looks good, and is pliable when you stick your fingernail into it, it's probably fine. AS someone else mentioned, when the engine is running, the valve is under vacuum which keeps it pressed shut. If you have doubts, squirt a little gasoline or starting fluid around the valve and see if it changes how the engine runs. Just make sure your squirt does not go into the metering unit, or that will change how the engine runs.
joe912/62 03-07-2023 12:52 PM
Okay thanks for the tip. As the weather gets warmer I would like to check the timing, oxygen sensor and maybe do a valve adjustment. Don't know when it was last done. I have only had the car 2 years now. I've done it on my old 912 but not a 911.
lateapex911 03-07-2023 02:34 PM
So, it was a intake runner not seated?? Crazy that the smoke went UNDer the shroud, and none leaked up. I guess your shroud is a tight fit against your intake manifold boss.
joe912/62 03-07-2023 03:38 PM
That's why it was so difficult to detect because nothing was coming up from the top even though the bolts were almost finger tight. I thought at first it was coming from the passenger side but removing the heater duct gave me a visual check inside. Car started right up afterwards. I was so careful to tighten all the hoses and missed the easier area's. I guess you always need to double check everything.
PeteKz 03-07-2023 10:01 PM
Too bad you didn't do the valve adjustment while you had the CIS off.
917_Langheck 03-07-2023 10:11 PM
No worries about that, Joe's now a CIS installation expert.
David Inc. 03-08-2023 05:14 AM
Told you it wasn't our little pal the green wire. ;)
boyt911sc 03-08-2023 06:09 AM
Good Job.......
Welcome to the CIS club. Next goal is to learn to drop the motor for better and efficient troubleshooting.
Tony
ZeroHecksGiven 05-13-2023 03:15 PM
Thanks for all the helpful responses and updates here. I'm currently going through a no start issue and reading all this gives me some hope and also some reason to take the smoke test seriously. Will be doing a DIY smoke test in the next couple of days.
Anyways, good stuff here, thank you!
