Simple on/off toggle that replaces headlight washer switch?
I am looking for a simple on/off two-position switch that fits in place of the headlight washer switch. Possibly something from a 964? I thought I found it with part #964-613-325-01-01C-OEM from our host but, this is also a temporary switch like the oe washer.
http://i.imgur.com/pnEVAmf.jpg |
There’s a rear wiper switch that will work.
I took apart my washer switch and removed the spring. This way it looks stock but functions as a toggle. |
Are you trying to use it as a kill switch? I wouldnt want the headlight washer running in just on off mode. That pump / wiring draws a lot of power.
Get over to mouser.com or digikey.com and lose your mind over the thousands of options. You’re certain to find what you’re in search of and without any Porsche tax.
i suggest a 3 prong so its lit at night?
The power window selector switch appears to be the same size/style. I repurposed mine as a oil cooler fan switch.
| All times are GMT -8. The time now is 11:13 PM. |
