901/911 Ring and Pinion
I’ve searched
Is there a source for new ring and pinion gears for the 901 / 911 transmissions? Otherwise, they are all at least 50 years old with unknown mileage / wear Thanks in advance |
Albins is an aftermarket supplier. I do not have any experience with Albins but they have been represented by those more knowledgeable than I as suitable for track use. I think the expected useful life may be shorter than OEM. YMMV
If you give your word: keep it. |
Check with Matt at Guard Transmission.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
gearhead
I don’t stock them, but I believe they are available from Porsche Classic for around $4k.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Another option is Albins, a reputable supplier of transmissions and parts thereunto. In the US, Retro Sport is their distributor.
https://retro-sport.com/porsche-gears/porsche-901-904-gears/porsche-901-ring-pinion
PCA Member since 1988
$4K? Ouch. I would not worry about a used R&P if the contact patterns are normal.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
It's the line below the contact point
I posted this wear pattern which we believe the R-P are worn and as a result there is rear end noise. It is the extra line at the bottom of the gear tooth
Which did you think made it cheap: the word "vintage" or the word "Porsche"?! Cheers,
Hah, hah. Yeah, I've discovered that over the many years I've owned Porsches. A couple thousand dollars here, a couple thousand dollars there--pretty soon you're talking about real money...
It just seems that the number of zeros have increased in the past few years.
Anyone see a rub pattern like this?
gearhead
Show us the condition of the pinion gear teeth. They touch 4 times for every time the ring spins once.
