Will Mocal Oil thermostat fit?
Our host has this oil thermostat listed https://www.pelicanparts.com/More_Info/BATA0T212.htm?pn=BAT-A0T2-12&bc=c&SVSVSI=0564 and it says it will fit my 1977 911. The threads are 180 degrees from each other , where the factory are on a 90 degree. Has anyone used this Mocal one? any pics? Reviews?
Shawn 77 Targa with 2.7 My never-ending work in progress that has been off the road since Mar 2004
I'm running this in my SC rally car. Seems good overall and allowed me to run -12 with no issues.
Thank you. Do you have photos of the install?
It's not an exact replacement for the Porsche external thermostat and it won't interface with the stock oil lines (if that's what you're looking for). That will all be obvious when you see pictures...
Otherwise Elephant Racing have one that matches OEM design
1977 911-S Modified (3.0 SC Motor/Flares) |
Likely irrelevant for your use, mine is mounted in the interior.
