Battery Terminal Crimper
I'm replacing my positive battery clamp with an original one, the big German style. Anyone know what kind of crimper works for this? The metal looks heavier than a standard terminal lug.
This sucker.
1982 911SC
Old 03-12-2023, 04:10 PM
Bought this crimper for welding cable terminals, it worked great. Probably good for battery terminals too.
https://www.amazon.com/gp/product/B0811VYCQ6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old 03-12-2023, 04:27 PM
dlagerstrom's Avatar
The crimper 540964 mentioned does work pretty well. I have one as well.
Just note that the dies are made for metric sizes. You will have some little ears spreading out from the gaps between the dies.
Normally, I believe crimping is the best method for proper electrical connection, but that assumes you have the proper crimper. With battery cables, I would suggest heating with a torch and melting some solder in after crimping.
-Dave in Minnesota
96 C4 Cab, 85.5 944
82 SC Targa SCWDP #0023
82 928
67 912 60 T-5 B Cabrio
Old 03-12-2023, 05:28 PM
PCA Member since 1988
If you're on good terms with a welding supply shop, you could probably get them to crimp it for you for a few bucks, instead of buying another tool you'll only use once.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-12-2023, 05:31 PM
I take my cables to a local marine supply store, they are cheap and will do it on the spot. Helps being near lots of water though.
Old 03-13-2023, 06:12 AM
This sucker.
I would think that type of terminal is meant for soft soldering. Using a gas torch heat it and fill with solder. Clean the wires with flux and heat the solder until molten, then plunge the wire in. Far nicer than crimping.
Old 03-13-2023, 06:33 AM
Danimal16's Avatar
This sucker.
Use Soldier Pellets with that terminal, it is not designed for crimping.
Dan
Old 03-13-2023, 07:16 AM
You guys sure? This is the OEM fitting and the one in my car currently has crimp marks. Were they soldered from the factory and maybe this one was previously replaced by someone else?
1982 911SC
Old 03-14-2023, 08:00 AM
Danimal16's Avatar
I have used the pellets, far better than a crimp.
Dan
Old 03-14-2023, 08:03 AM
Am I going to be able to get away with doing that with the cable in the car? I've always been a crimper so I'm not familiar with larger gauge soldering.
Edit: I think the last time I soldered anything was a few circuitboards in higschool tech class in.... 1999?
1982 911SC
Old 03-14-2023, 08:18 AM
Danimal16's Avatar
I have done it in the car.
It can be a challenge but just take your time.
Here is a link that explains the concept.
Summit Racing sells the pellets as well as numerous battery and cable supply companies.
Dan
Old 03-14-2023, 08:57 AM
Very cool, thanks for your help!
1982 911SC
Old 03-14-2023, 09:08 AM
Racer
winders's Avatar
A crimp is the best way to go and FAR superior to pellets or any other kind of soldering.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 03-14-2023, 09:10 AM
1982 911SC
Old 03-14-2023, 09:29 AM
Crimps are far easier to effect than soldering which is why manufacturing has gone that way. From a technical point soldering is far more effective and less affected by damp, corrosion etc. So if it’s your car and you care then solder it.
Old 03-14-2023, 03:00 PM
Buy a set of dies and use a press or a vice if you don't have the hydraulic crimping tool.
https://www.amazon.com/Lichamp-Hydraulic-Crimper-Replacement-Terminal/dp/B098QZY16N?source=ps-sl-shoppingads-lpcontext&ref_=fplfs&psc=1&smid=A2XME1H7U96JBD
If you soldered wires when it really counts, like satellites or spacecraft or aviation, you'd be laughed right out of the shop. Soldering is NOT superior to crimping.
And if you look at splices in OEM harnesses, you'd see that they have moved away from even crimping and now ultrasonic weld the wires together at splices.
Google any of this stuff if you don't believe us.
Old 03-14-2023, 03:58 PM
Racer
winders's Avatar
This is totally incorrect. Look at the wiring harnesses used in any motorsport series and you will find almost no soldered connections. The only time solder is used is when there is no other option. When solder is used they usually encase the soldered joint in epoxy so it is less susceptible to vibration.
Crimping is massively superior to soldering...
Scott Winders
PCA GT3 #3
Old 03-14-2023, 10:16 PM
proffighter's Avatar
Absolutely right. Even NASA says so:
https://workmanship.nasa.gov/lib/insp/2%20books/frameset.html
Roland
930 Turbo '81 Too many modifications to list
Old 03-15-2023, 04:01 AM
