‘85 911 Sway Bar Bushings
When replacing the sway bar drop links and bushings on my ‘85 911, I quickly discovered a previous owner retrofitted the original 18mm sway bar with a 21mm bar (911.701.11 which I believe is for ‘87 - ‘99?). The old bushings are 477.411.313D.
I can find 21mm 447.411.313 M bushings but not 21mm 447.411.313 D.
Questions: What is the difference between M and D bushings? Are they interchangeable?
Thank you!
Old 03-19-2023, 01:32 PM
Mark Salvetti's Avatar
I did find the D here at Pelican: https://www.pelicanparts.com/More_Info/477411313D.htm?pn=477-411-313-D-INT
But if you look at Sunset Porsche parts, they have the M version and it says it replaces the D.
So I think you are fine with the M.
Mark
1979 911SC Targa
Old 03-19-2023, 03:44 PM
I must have fat-fingered it when I did a Pelican search. Thank you, Mark!
Old 03-19-2023, 04:52 PM
