Original appearance front trunk perlon recommendation?
Looking to replace the original dark grey front trunk liner (perlon) in my 1988 3.2 car, partially consumed by the little guys. Need factory original appearance, and not looking to upgrade to carpet or other.
What is the currently available closest match to the original? The later 3.2 cars have a molded "pouch" for the fusebox and velcro strips to adhere the sections together, so apparently they're a bit unique in that aspect: * Pwlican sells 3 listings for AppBiz, and I found mixed reviews on others * Ebay lists a specific set for 86-89 applications * Porsche still lists part numbers for the three sections individually as "special order" but no images to determine appearance Thanks for your advice! |
Carl
I didn't think about it but I have the large section of the factory perlon that you could have made into the section you need? |
Why thank you Bob - unfortunately since it is the fusebox side (with pocket) I do not know of anyone in my area who could make into such.
| All times are GMT -8. The time now is 01:41 AM. |
