Distributor green wire
How do I test the green wires going to the distributor? Can I just pull on the connection and check for continuity at the 2 pins ? Do I need to remove the distributor to pull the plug off ? Also in the Bentley manual it states to test the CID connection between terminal 7 and 31d check while engine cranking and test for voltage (VAC) , what is VAC? I tested for power at #15 terminal and have power there.
Old 02-27-2023, 04:47 PM
47silver's Avatar
What is the problem you are investigating
Old 02-27-2023, 05:20 PM
Want to verify if the wire is my problem with the no start issue. Car starts and turns off.
Old 02-27-2023, 05:31 PM
If it shuts off after getting warm could also be CDI. Usually just wiggling the green wire and getting the undesired outcome is the test. I had one intermittent. Initially thought it was my CDI acting up again. Bob had serviced it the first time. He retested/stressed and it would not fail. I started moving the green wire one day while it idled in my driveway and got the car to stall. No issues after the replacement wire.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 02-27-2023, 06:59 PM
The green wire at the CDI should measure about 600 ohms and about .60 ACV while cranking.
Dave
Old 02-27-2023, 07:18 PM
Really? Life time warranty, right?
Dave
Old 02-27-2023, 07:20 PM
The distributor has to come off to pull the wire. At least I can't see how else to do it.
If it starts and then stalls the same way every time it's not that wire.
1982 911SC
Old 02-27-2023, 07:59 PM
47silver's Avatar
Take a spare plug, take off a spark plug wire, ground the plug. Have someone turn key or record with phone and see you have spark
Old 02-27-2023, 09:29 PM
@mysocal911 - not sure you understood my comment. Bob's product and warranty are stellar. He tried to make the CDI fail by stress testing with hot conditions and it would not fail. It was clear at that point it was not the CDI.
Old 02-28-2023, 04:54 AM
So I can test at the CDI connector which is easier to remove?
Old 02-28-2023, 06:15 AM
If your car is like mine (1978SC) then you can disconnect at the two pins near the chain case and test for continuity; if you have continuity between the two wires then the green wire has shorted and needs to be replaced. You have to remove the distributor to replace it.
Roy
1959 Bristol 406 (bought in 1972; sold in 1977)
1966 Porsche 2.0 coupe (bought in 1977; sold 1981)
1978 Porsche SC coupe (bought in 1993)
Old 02-28-2023, 07:21 AM
Sorry which 2 pin connector near the chain case?
Old 02-28-2023, 09:10 AM
Can you describe the engine shutoff issue? When it cuts out? Might get your best feedback like that.
1982 911SC
Old 02-28-2023, 09:37 AM
So what it is, i.e. days/months/years?
Dave
Old 02-28-2023, 10:00 AM
Well it's 2 year, but Bob is a pretty good dude. If he's still in business when your CDI were to break 50 yrs down the road I'm sure he'll fix it for you.
Old 02-28-2023, 10:22 AM
Very simply starts and dies. No idle whatsoever.
Old 02-28-2023, 11:00 AM
Can you keep it running by giving it throttle? What are you calling a "start"? Like it will get some ignitions but not turn over on its own when you turn the key off ignition back to on? Does it rev up with RPM on the tach for a second before dying? So many unknowns but definitely doesn't sound like the wire if it's firing at all.
1982 911SC
Old 02-28-2023, 11:21 AM
Can you post of video?
Old 02-28-2023, 12:08 PM
It revs up to RPMs on the tach and shuts down.
I could try to get a video tomorrow
Old 02-28-2023, 12:18 PM
That'll be helpful, but almost 100% not the green wire if it revs.
1982 911SC
Old 02-28-2023, 12:46 PM
