Senior Member
AC Delete engine panel
I am sure I am just not using the right phrases in search, but cannot find anything WRT a block off plate for the engine bay after removing the AC compressor and bracket.
With my clutch done, I am on the home stretch with spring plates and sway bar bushings, so will begin the long process of prepping for electric AC next year. Will be nice to get the bracket out of there and clean up a bit.
Is there a panel that is available and I am just not seeing?
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 03-23-2023, 06:13 PM
I did the full heat back-date AC delete on my 3.2 motor. As far as I could find there is no "delete" rear tin. I fabbed up some patch panels and tig stitched them in place.
I'm sure I have pics of what I did. PM me tomorrow if you'd like me to post them. Not at that computer...
Old 03-23-2023, 07:49 PM
Senior Member
Thanks Solamar - will do.
Chris
Old 03-24-2023, 03:00 AM
PCA Member since 1988
FWIW, I just used some black silicone seal and gutter flashing, painted black, to cover those gaps. Easy on, easy off.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-24-2023, 07:11 PM
Could you please post a picture? TIA
Old 03-25-2023, 11:02 AM
Would love to see picks of the heat back-date. Thanks.
Old 03-25-2023, 11:03 AM
Block off plate
I built this removable plate out of sheet metal. I thought it turned out pretty good for not being a sheet metal guy.
Old 03-25-2023, 01:35 PM
Goatfarmer1970: I’m having trouble posting pictures on the forum. SparkysVega is neater than mine, so use his picture.
Old 03-25-2023, 01:45 PM
This shows the heat back date and AC delete pretty well. Looking for pictures of my rear tin that show the patches, will post them if I find them.
1978 SC Targa
Old 03-27-2023, 09:00 AM
