HELP!!! 3.2 Chugging/Stalling
Hi all -
My '85, once it warms up, will start to lose power (see video). Initially, it's just split-second blips, but will progress into longer power losses and sometimes stalls (sometimes unrecoverable stalls until it cools down). This problem started last March; mechanic worked on it for two weeks, then had to stop as it was shipping with me from US to Portugal. The car shipped and sat until October, when my shop over here was able to work on it. Finally got the car in January (delays on registration). Drove fine for a while, but started chugging again two weeks ago. Shop thought it was the DME and is sending it out for repair. Lent me another DME so I can drive while waiting; same problem started once the car warmed up - returned it to the shop. Here's what's been done to date: US: - ECU: Tested good - Idle Speed stabilizer: replaced - Air flow meter: Tested good - Crankshaft Position Sensor: replaced - Idle Air Control Solenoid: replaced - DME Relay: Tested good - DEM Connection points: Tested good - Ground points: Tested good Portugal: - Ignition Coil: Tested good - Rotor: Replaced - Spark Plug Wires: Replaced The MAF was originally believed to be the issue: Cleaned Videos: https://youtu.be/2wg_YYvyOMM https://youtu.be/69YW7eJzGuA Appreciate any thoughts. Thanks! |
I just dealt with a very similar issue on my '85. The issue seemed to present itself once I got the engine up to operating temp. I'd start to lose power, the idle would drop, and it would take some effort to keep it from cutting out. My mechanic was able to blip the throttle through it and then it would be fine for the remainder of the drive; the first time it happened to me it was very difficult to restart the car because the idle was so low and applying throttle seemed to kill the engine.
The mechanic's suspicion was that it was one of the three sensors on the left of the engine (temperature, cylinder head temperature, and top dead center reference if I'm not mistaken). Oddly enough, everything tested within spec when he took a multimeter to it. In the end, we replaced the temperature sensor and I haven't been able to replicate the issue since. I hope this helps and that your fix is a quick one! |
i see your alt. light is flickering when the miss has happened....
Ivan |
Yeah, I would check for loose wiring and the voltage regulator. Stick a voltmeter on the cigarette lighter and see if the voltage's fluctuating.
Battery could be kaput as a result. Any funny smells from the battery ? |
What sucks is I've had some extremely competent Porsche mechanics on this and nothing yet... |
End result: The shop swapped out the ignition coil from another 3.2 and it ran fine; thought that was the problem until they put the original coil back and it ran fine with that. Only thought was maybe the connection was bad, and unscrewing/screwing was enough to clean the contact and resolve the issue.
None of us are 100% on that answer, but it's running strong for now... |
Congrats.
Thanks for updating. |
Well... problem NOT solved! Took the car overnight about 3 hours South - ran great. Next day - about 45 minutes into the drive heading home - same issue. Started loosing power for a second or two, then 5 to 10 seconds, then eventually died. Wasn't able to restart it immediately; restarted after cooling down. Had it towed back to my shop.
BTW - we noticed a burning smell when it died, but weren't able to identify it. It's gotten worst at the shop. The engine no longer needs to be warmed up for the problem to occur again. The car runs fine at idle, but starts to choke when the throttle is pressed. If they lay off before it dies, it will return back to idle. My shop doesn't have an easy answer... they are solid classic Porsche specialists and haven't seen this before. Next step is to start best-guess replacing parts, which is not going to be cheap, otherwise I'm left with a Porsche paperweight. |
Curious if you have checked your fuel pump?
A friend had a car with slightly similar issues... we thought it was the dme relay...
But it turned out to be the fuse for the fuel pump... the connections had corroded partially reducing the power flowing through... Rotating the fuse to "clean" the connections got the car running again. After cleaning all fuse terminals, it's run fine since. Who knows.. maybe something similar for you? |
The fuse panel was replaced with an Adapt Motorsport mini-blade fuse panel. It has LED indicators for fuse status; green is good, red is bad. All showing green. |
how about fuel press.regulators? have you look at them?
ivan |
I would find another shop that knows how to troubleshoot
Thanks! |
Looks like you're mostly looking at controls and electrical, have you changed the fuel filter(s), checked fuel pump/ wiring/ fuse, looked in the fuel tank?
Sent from my Pixel 7 using Tapatalk |
I hate to be the guy that suggests things to a shop that works on 60's to 80's Porsches every single day, but at the end of the day it's my money. |
Ivan once you know if that is the problem, ..ask Tony-boyt911 here he just went through this ,last year ,i think and he got the reg for MBZ for much less money since the 911 is 420 euros... |
They should know how to check fuel pressure and flow. If either of doesn’t meet specs then investigate further. Or you could just guess it’s the fuel pump.
Guessing which part has failed can be an expensive way to fix a car. But eventually you will guess correctly! |
Update: After a lot of testing (electronics, fuel system and pressure, etc.) the cylinder head temperature sensor was replaced. Car was ran for extended periods without issue. MAYBE it's fixed this time???
Thanks again for all the input! |
| All times are GMT -8. The time now is 11:45 AM. |
