Quartz Clock Conversion
Here's another one of my crazy projects. I blame it on the pandemic!
Like the way most of the other projects originated, I was looking for a way to convert an old Kienzle (pre-74) clock to quartz. I've fixed a bunch of these early clocks and it's usually the thermal solder fuse or messed up gears. The problem is that even after servicing them they don't keep time like a quartz or modern clock. The usual shops charge $400-$500 for this conversion which seems a little pricey. The goal was to build a quartz movement, based on a VDO movement, that would fit inside the plastic cover on these old clocks and be able to use the early needles. Like most projects of this nature, it was easier said than done.
I'm still working on a movement that would be a direct replacement for the mechanical movement, but I put this one together that checks off most of the boxes. This one is based on VDO's latest clock design which uses a stepper motor and modern electronics. Since it doesn't use the typical gear driven movement, like in most of the quartz clocks, this one can not be adjusted from the manual adjuster on the front of the clock. That's the downside, but the upside is you end up with a very clean looking silver button clock with a flat glass lens.
I started with the latest VDO clock and designed 2 circuit boards that were used to assemble a clock module with the same dimensions as the original Kienzle clocks. It requires modification to the needles but the early needles are retained.
Thanks to the Pelican members I was able to pick up a few early clocks so my plan is to build a few of these and offer them to Pelican members. I put a "Carrera RS" script on this one but I can do almost anything on the faces.
Here are some pics of the clock......
Picture of the custom module next to the original Kienzle clock
Picture of it installed on the clock
Picture from the front
Picture with the plastic cover installed - Looks stock
....and the finished clock without the glass and bezel
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 12-23-2020, 08:27 AM
1988 Carrera
shadowjack1's Avatar
This looks so nice.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 12-23-2020, 10:29 AM
How do you set the time, with no glass adjustment knob. Rob
Old 12-23-2020, 06:46 PM
2 options to set the time. There is a little orange button on the back that can be used to set the time but obviously the clock will need to be removed to set it. The other option is to put a button under the dash, like the odometer trip reset or sunroof switch.
Old 12-24-2020, 07:18 AM
Apropos of nothing, the Porsche dealer in Las Vegas was selling NEW clocks for $418.00. Bought one to replace the 37 year-old clock in my '83. Works like a champ!
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 12-24-2020, 10:34 AM
Looks great
Old 12-24-2020, 12:21 PM
Hi, I’m wondering if you might contact a brother that is trying to do something similar for a VDO clock in his Volvo 1800ES.
If you wouldn’t mind his contact info is
jimperry@pandbmotorsports.com
920.594-1337
Old 03-31-2023, 08:53 AM
I have an acquaintance with a Volvo 1800ES with VDO gauges that is very interested in your adaption. He is not on this forum, can he somehow get in touch with you?
Old 04-04-2023, 07:29 AM
SCadaddle's Avatar
I bought my 82 SC with 150k on the odo 11 years ago quite simply because the clock was actually working. I knew it was a special car. The clock is still working now.
Found a broken head stud shortly after purchase, but they all do that. Hehe.
Old 04-04-2023, 08:10 AM
I lucked out and snagged 2 VDO movements that were originally used for european trains to show different time zones, NOS. Sometimes the movements come up as they were used in more than just cars.
Does this mod require changes to the movement, or direct replacement?
Old 04-04-2023, 08:17 AM
I'm really sorry, but I've just been too busy lately to take on anything other than 65-89 Porsche gauges. This is supposed to be a hobby
I'm not sure what you're asking? This conversion is something I designed and built to completely replace the Kienzle mechanical clock movement
Old 04-04-2023, 08:56 AM
7783911's Avatar
John
is it or can it be battery driven?
1977 911-S Modified (3.0 SC Motor/Flares)
Old 04-04-2023, 12:14 PM
Originally Posted by 7783911 View Post
John
No, this design is based on a 12V VDO clock.
Old 04-04-2023, 05:13 PM
PCA Member since 1988
Well, technically, it IS battery driven--by the 12v battery in your car! As for building batteries into it, you could figure out a way to substitute 12 volts worth of small batteries (like a stack of 4 CR2032's), but why would you want to? It would be more trouble than it's worth.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-05-2023, 01:37 AM
7783911's Avatar
Pete
I m always looking for ways to remove wiring and or source of parasitic draw, its not critical, just curious
Old 04-05-2023, 05:06 AM
Technically that is correct.... to go even further, there is a 3V regulator circuit in the clock so technically that could be removed or bypassed and it could be run off a single CR2032 or a couple of AAA batteries. However, I'd put that in a bucket of project that I have on my desk that probably wont get done
Old 04-05-2023, 07:04 AM
You would still need the wiring to the instrument lights for night driving--unless you don't care what time it is at night!
Old 04-05-2023, 12:08 PM
7783911's Avatar
True, but But that is a switched circuit
Old 04-05-2023, 01:02 PM
