-   -   Front Trunk Related Parts (http://forums.pelicanparts.com/porsche-911-technical-forum/1137320-front-trunk-related-parts.html)
Hawkeye's-911T 03-28-2023 01:24 PM
Hi Guys
No luck with the PET or any other after-market supplier diagrams etc. Does anyone know of a Porsche part # for the grommets & a source for the bulkhead style ring-type(?) seals from the trunk to dash interior for the (fog, ciggy lighter & rear window de-fogger) switches?
http://forums.pelicanparts.com/uploa...1680033603.jpg
"Old" pre-resto interior Dash view
http://forums.pelicanparts.com/uploa...1680033480.jpg
Trunk side View showing seals parts in question - the grommet for the rear de-fogger disintegrated completely - the one on the left is basically useless - the one on the right might be re-usable(??)
http://forums.pelicanparts.com/uploa...1680034130.jpg
Top view through speaker opening showing location of the 3 bulkhead style seals in question.
I also need some advice or recommendation on what covers or blocks the rather big hole accessing the steering gear.
http://forums.pelicanparts.com/uploa...1680033852.jpg
Any help or advice will be appreciated
Thanks & Cheers
JB
EC900 03-28-2023 01:41 PM
I’m sure you can find a standard pass-thru grommets at the auto parts store.
As for the opening in the steering column, there wasn’t any. Someone posted the same query a few months while back.
My reply was that my ‘77 with dealer installed AC, the kits they used had supplied a generic foam sponge block to wrap around the shaft/tub to seal this opening, probably to help keep dust and debris from the evaporator to a minimum. Tucking any sort of similar material like that of rubber pipe wrap might do the trick, it’s just hard to seal completely.
Lz7w 03-28-2023 08:04 PM
I think the grommets might be 999 703 066 50 and 999 703 067 50 (from 810-10 in the parts catalog): http://www.***********.com/porsche-parts/hardparts.php?dir=911-65-69&section=801-10
but maybe someone else knows for sure?
Hawkeye's-911T 03-30-2023 11:28 AM
Hey Lz7w - Thanks for the part #'s - I'll chase those down
Cheers
JB
Classic 04-05-2023 01:15 PM
JB,
Part numbers on your EarlyS post
