-   -   Removing AC bracket without dropping muffler (http://forums.pelicanparts.com/porsche-911-technical-forum/1137352-removing-ac-bracket-without-dropping-muffler.html)
FA-18C 03-29-2023 08:29 AM
Is it possible to remove the AC bracket without taking the muffler off on an 88 911? My mech mentioned that I do not need to take it off, and I should have yanked this when the engine was out - what was I thinking?
Looking at other threads, it looks like with some skinny wrenches I should be able to remove the last two bolts going from below, and the 8mm hex under the top plate. Doable? Or should I be drug tested on this?
86 911 Targa 03-29-2023 11:03 AM
Bracket
I think you have answered your question.
No need to remove anything in advance.
Semper Fi
Gerry
brianlay 03-29-2023 01:30 PM
I recently re-installed my bracket and had to drop the muffler to do it. I think you will struggle without dropping it
dtwa 03-29-2023 07:38 PM
I took my bracket off w/o removing the muffler. I did have to undo the mounting straps on the muffler and remove the crossover pipe for the heat exchangers. I could then access the two (I think) bolts holding the aluminum AC bracket to the steel bracket surrounding the crank pulley. —Dave
