ADDvanced's Avatar
Oil tensioner line is too short, help?
Okay so I got my car running (finally), but I noticed an oil leak right away from the drivers side oil line that goes from the distributor area to the side of the head and feeds the timing chain tensioner.
Not sure what to do. Part # is 930-107-347-14, which Pelican says will fit my 1977 targa.
I mean theoretically I could go to the hardware store and maybe locate a metric brass fitting to extend this but I’d rather just have a line the correct length.
Can anyone shed some light on this and what is going on? Are 77s supposed to use a weird line that backdates the spring tensioners to oil?
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-05-2023, 06:02 PM
ADDvanced's Avatar
Anybody? I can't be the only person who's had this issue. There is no way the new line is usable.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-06-2023, 08:01 AM
proporsche's Avatar
looks like a bad batch -return it to the seller.It happened to me here in Europe from rose passion too..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-06-2023, 10:31 AM
MBAtarga's Avatar
Does this help any? I'm not following all the different PN's but maybe you've got a wrong one.
Oil Line to Camshaft Carrier
Mark
'83 SC Targa - since 5/5/2001
Old 02-06-2023, 10:32 AM
Titanium User
Might be easier to bring it to a hydraulic line shop and having the rubber hose replaced with a longer one.
Buy some Titanium Lug Nuts!
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1032311-fs-titanium-lug-nuts-studs-v2-0-a.html
ig: @ti_porsche_products
Old 02-06-2023, 10:41 AM
ADDvanced's Avatar
Thanks for the link, I explored the part numbers talked about in there:
930-107-347-06 = Not correct, this has no rubber section, and no fitting for the oil line to the tensioner
930-107-347-09, same problem:
I don't get it. I don't see how this line could ever possibly work, given how short it is. Do later cars have a longer fitting near the distributor????
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-06-2023, 10:50 AM
Several years ago the metal went from gold to silver and in doing so moved the connector on the hose. The drop to the tensioner needs to color match to fit correctly ..or bend what you have to work.
Bruce
Old 02-06-2023, 12:06 PM
ADDvanced's Avatar
I don't know how bending it will make it an inch longer.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-06-2023, 01:29 PM
PCA Member since 1988
Send pictures of the lines installed on the engine. And where is the old line/hose leaking?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-06-2023, 10:37 PM
proporsche's Avatar
i try again to give u a hint...sent it back to the supplier....
Ivan
Old 02-07-2023, 12:26 AM
LJ851's Avatar
I had the same problem and bent the line to make it the correct length.
Old 02-07-2023, 04:01 AM
ADDvanced's Avatar
Visible at 7:33 here:
https://youtu.be/ToRYPNVMBH4?t=453
It's leaking from the rubber section, I believe the rubber hose is collapsing/deteriorating
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-07-2023, 09:16 AM
That video shows the chain tensioner supply pipes fitting correctly. What am I missing?
The rubber hose fitting does leak after many years. Replacements aren't very expensive at Pelican. The last one I bought was about $40 (right side). Not worth getting the old one rebuilt for that price.
Old 02-07-2023, 04:09 PM
ADDvanced's Avatar
That video shows my ORIGINAL gold (leaky) hose. I started the engine and it leaked. The new one is about 1" shorter than my old one.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-08-2023, 07:20 AM
I agree with Ivan. Send it back and get the correct length.
Old 02-09-2023, 01:28 AM
Senior Member
Looks like the hard fitting is definitely short, they may have mislabeled the fitting during the build and didn’t catch it. I think you could take it to a hose shop and insert a longer middle section and make it work, that would be the fastest way here…
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 02-09-2023, 04:54 PM
ADDvanced's Avatar
So... I just tried returning this to Pelican, and ordering the official Porsche one... then a week went by, and now they're saying that part has to come from Germany, because there aren't any in the united states. I find this hard to believe. So many people are building aircooled engines here, and yet there is not ONE brand new oil line? Anywhere?
They also want to charge me for shipping from Germany now. This is so annoying. I just want a part that fits.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-28-2023, 09:25 AM
I went through this when putting my 2.7 case motor together.
They have a variety of lines that you can order none if it was clear, what i did was order all of them essentially and send back what I did not use.
if you want help with that let me know Ill get the PN i used and we can compare it to the ones you have.
1976 914
1986 951
Old 02-28-2023, 10:24 AM
proporsche's Avatar
[QUOTE=ADDvanced;11935283]So... I just tried returning this to Pelican, and ordering the official Porsche one... then a week went by, and now they're saying that part has to come from Germany, because there aren't any in the united states. I find this hard to believe. So many people are building aircooled engines here, and yet there is not ONE brand new oil line? Anywhere?
do you know anybody at SSF autoparts? what about the dealer?
Ivan
Old 02-28-2023, 10:47 AM
ADDvanced's Avatar
They said none of the dealers have them except for the ones in Germany. I just find this super hard to swallow; my BS detectors are going off hard right now.
IG@ADDvanced
Youtube@ADDvanced
www.gruvdesign.com
Old 02-28-2023, 10:51 AM
