echecsqueen's Avatar
Door juts out at bottom
My driver side door juts out at the bottom front quite a bit. The rest of it looks ok. Does anyone know a easy fix or is this another Pandora’s box?
Old 03-27-2023, 08:38 PM
Sorry. Photo didn’t post
Old 03-27-2023, 08:45 PM
proporsche's Avatar
yup, adjust the door hinge 3 bolts.They are usually painted so if you lose them i suggest to repaint them..in your case the upper too.Can we see them with the door open?
do you have like this since ever?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-27-2023, 11:23 PM
You can also try adjusting the latch on the door jamb. This latch was designed to be adjustable, but it often rusts in place due to years of water, debris, etc. in the wheel well.
Old 03-28-2023, 05:20 AM
Check bottom of front fender first. Might be able to move that out a bit to compensate, easier than screwing with door.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 03-28-2023, 05:59 AM
The latch side of the door doesn’t protrude or go in. I just don’t want to end up with a door that doesn’t operate well after reading about door adjustment problems when toying with the latches.
Here are some more photos. I appreciate the help.
Old 03-28-2023, 08:00 AM
proporsche's Avatar
can i see the upper and bottom hinge? where the pin goes through?
Looks like you had some welding done on the door stop,right?This problem with the door usually happened when the door stop broke and the door went too far ,let`s say with the wind...
the bracket inside the door is horrible..why don`t you get the repair kit for it?Or you have nothing to repair it with ,no metal left?
here
https://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/74-Door_Stay_Reinforcement/74-Door_Stay_Reinforcement.htm
Old 03-28-2023, 10:08 AM
I don’t think I have enough metal to use the kit.
Maybe I should try?
Top hung first then bottom
Old 03-28-2023, 10:30 AM
Bottom
Old 03-28-2023, 10:32 AM
Hinge area with and without tension
I haven’t done any work on the hinge but PO may have
Old 03-28-2023, 10:35 AM
proporsche's Avatar
yup, looks like you do not have much room left,the door got twisted - opened too far.
But what you can try,you are crafty enough.Disconnect each hinge at a time and try to grind the hole into an oval shape,maybe it could give you couple on mm to play with the adjustment...
Also get rid of this new type of door stop- they are way to strong.Try to get the old type ,which is much softer and not so hard on the door itself.
this one
https://www.thesamba.com/vw/classifieds/pix/8271303.jpg
Old 03-28-2023, 10:41 AM
Thanks Ivan- will give it a try.
Old 03-28-2023, 10:44 AM
Looks like somebody has already screwed around with it. Hinge bolts have been loosened, and hinges pushed in all the way towards driver. Repairing the door stay is not going to fix the issue.
Like I said see if you can correct the gap by moving lower part of driver fender out a little bit. Only other option is to make hinge holes larger and push in more or remove door and fix or replace.
Old 03-28-2023, 10:56 AM
I may have a little more play to push in a mm. Man these bolts are hard to loosen.!
Old 03-28-2023, 11:42 AM
Nah. It didn’t give me anything. When I feel energetic I will take it off and bring the holes towards the hinge pin a few mm. Thanks guys
Old 03-28-2023, 11:45 AM
Zeke's Avatar
The fender lines up with the rocker nicely. Doing that and it won't.
Old 03-28-2023, 03:18 PM
Apologies for stating the blindingly obvious but there does appear to be witness marks on the hinge plate indicating where the bolts might previously have sat. Is it worth trying to move it back the those places?
Old 03-29-2023, 12:31 AM
Easily adjusted
Old 03-29-2023, 06:09 AM
Aligning hinges with witness marks your referring to would bring the door out even more.
Old 03-29-2023, 06:10 AM
It appears that your door was sprung or opened too far which pulled the metal and lower hinge out a bit. You can tell previous owner tried to compensate by moving hinges in as far a possible.
If your up to it remove door and see if you can hammer the hinge back down a bit, use a piece of wood between hammer and metal obviously.
Old 03-29-2023, 06:23 AM
