-   -   Does your battery indicator light come on when turning car off? (http://forums.pelicanparts.com/porsche-911-technical-forum/1137513-does-your-battery-indicator-light-come-when-turning-car-off.html)
Sajan 04-01-2023 09:38 AM
Just curious, if your battery light (in the same cluster as the oil temp/oil pressure) come on as the car is turning off.
i.e. once the ignition is switched off, as the engine is shutting down, does the light come on?
EC900 04-01-2023 12:10 PM
Its the Alternator light.
I’d check the output condition of the battery, connections and it’s age. Might be that it’s time to replace it if over 4 yrs. old.
With engine running use a multimeter and reading should be better or close to 14v. With engine off anything less than 12.5 would indicate the battery is not able hold a charge.
Worse case is when engine is running, the alternator andd/ot regulator is failing or combo of all three, including the battery.
john walker's workshop 04-01-2023 03:44 PM
If the light stays on with the key off, the alt has a bad diode or 3.
Sajan 04-02-2023 09:41 AM
Sorry..to clarify..
I was referring to the quick second where the light comes on as the car is turning off.
https://youtu.be/Tc53duOahtM
Nditiz1 04-02-2023 02:51 PM
Mine does this too, seems normal
RNajarian 04-02-2023 03:25 PM
Mine also flashes on as I turn off the engine, maybe less than a second. Alternator is new so I assume it is normal.
Sajan 04-02-2023 03:57 PM
Thank you!
