Stainless Oil lines.routing check
Guys.Have finished fitting SS oil lines.I am using lens high rise hoses.Can someone please confirm the flow from engine, and return to tank is correct on this picture please.I cant recall how they originally run.Sure this image is correct.However,when I looked at the Elephant Racing image, they look reversed,or maybe just my eyes!
Old 05-30-2023, 08:49 AM
The first picture of the thermostat to the motor is correct.
Bruce
Old 05-30-2023, 09:45 AM
Yes it's correct. Why did you use metal pipes instead rubber ?
Wysane z mojego M2101K9G przy uyciu Tapatalka
Old 05-30-2023, 09:53 AM
Bruce
Thanks Bruce.
Old 05-30-2023, 11:28 AM
The long lines are originally brass.Not sure where you mean?
Old 05-30-2023, 11:29 AM
Bras for sure we're not on my however I can imagine that someone did pure job like with rest of the car.
Old 05-31-2023, 12:01 PM
Wow!
Old 05-31-2023, 12:12 PM
Joshuars - those are AC hoses in your photo leading to the dryer and condenser.
Old 05-31-2023, 12:50 PM
BoxsterGT's Avatar
Porsche Crest
Paul-
Along the rocker, the inner or lower line is the Oil Feed to the Cooler, the outer or upper line is the Return to the Tank.
Looks really good. I am happy to have helped.
Len
Old 05-31-2023, 06:05 PM
