Wire identification please
Found this wire under passenger seat near the Lambda box, seems like it's coming from the front of the car. Has a grey with red stripe and a brown with white stripe. Is this for the alarm?
http://forums.pelicanparts.com/uploa...1680375131.JPG |
Is it for the seatbelt warning light? It's on a 82SC
yes.
Does it connect to the seat belt mount at the floor?
On my 1973, it connects to a connector on the bottom of the seat pan. Your seat is different, but it should have that mating connector down there somewhere between or under the seats. It goes to the seat belt latch, so you could find it by following the wires from the latch. I think your latch is on the tunnel. It's the only one that will fit.
Found the other end and the pins have pulled out of the connector. I need to remove the passenger seat to reassemble it. How many bolts hold down the seat? I see 2 on the front of the rail and 2 at the back, no others?.
Thanks |
just the 4
Was able to re connect the plug without removing the seat. Moved the seat forward all the way and was able to access the other end and re-install the pins and re connect everything.
| All times are GMT -8. The time now is 12:37 AM. |
