Quaife in a 901 not that good??
Hello everybody, i recently installed a quaife in a 901 and so far its not that nice, it has killed the drifting of the car without providing a measurable upgrade. Am i doing something wrong or its just torsen for fwd drive cars and lsd (disc type ) for rwd and rear engine cars? So far the car was much more fun with the open diff
Thanks a lot |
What was the outcome you were looking for by adding a limited slip differential?
Slow old car
Is the quaife a torque-biasing or limited slip differential? Torque biasing will only be noticeable until one tire completely loses grip, then it acts like it’s wide open. Limited slip is a much more noticeable change, particularly when used as you’ve referenced (drifting) when you’re beyond your tires limits.
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
It's a 914 ...
A Quaife is definitely different from a limited slip. You'll get different behavior from a Quaife than you'll get from an LSD or an open diff. Quaife only makes torque biasing diffs and not LSDs for 911s to my knowledge. I'm a little surprised that an open diff would allow drifting better than a Quaife. At least the way I understand drifting.
It's a 914 ...
And by drifting, do you mean sustained tail out, smoking tires kind of drifting?
Drifting; go spool or welded.
gearhead
As another mentioned, if you want a drift car, get a spool. Or an LSD locked to 80%.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
