Quaife in a 901 not that good??
Hello everybody, i recently installed a quaife in a 901 and so far its not that nice, it has killed the drifting of the car without providing a measurable upgrade. Am i doing something wrong or its just torsen for fwd drive cars and lsd (disc type ) for rwd and rear engine cars? So far the car was much more fun with the open diff
Thanks a lot
Old 04-09-2023, 04:03 PM
r_towle's Avatar
What was the outcome you were looking for by adding a limited slip differential?
Old 04-09-2023, 04:19 PM
Slow old car
Is the quaife a torque-biasing or limited slip differential? Torque biasing will only be noticeable until one tire completely loses grip, then it acts like it’s wide open. Limited slip is a much more noticeable change, particularly when used as you’ve referenced (drifting) when you’re beyond your tires limits.
Mike
1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX
Old 04-09-2023, 04:21 PM
mostly controllability when drifting and being able to keep the car going sideways longer
Old 04-09-2023, 05:26 PM
the quaife is a torque blasting differential, it seems to cause a very unpredictable rear end
Old 04-09-2023, 05:28 PM
It's a 914 ...
stownsen914's Avatar
A Quaife is definitely different from a limited slip. You'll get different behavior from a Quaife than you'll get from an LSD or an open diff. Quaife only makes torque biasing diffs and not LSDs for 911s to my knowledge. I'm a little surprised that an open diff would allow drifting better than a Quaife. At least the way I understand drifting.
Old 04-09-2023, 05:38 PM
drifting takes much more effort with the quaife. with the open diff it was more controllable
Old 04-09-2023, 05:56 PM
It's a 914 ...
And by drifting, do you mean sustained tail out, smoking tires kind of drifting?
Old 04-10-2023, 05:23 AM
Drifting; go spool or welded.
Old 04-10-2023, 06:04 AM
gearhead
The Quaife is providing better traction and fighting your efforts to lose control. It’s actually doing exactly what it’s supposed to do.
As another mentioned, if you want a drift car, get a spool. Or an LSD locked to 80%.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 04-10-2023, 06:08 AM
