I am planning on purchasing a 123ignition distributor for my 71 911T. Although it looks like I could probably do this myself, I don't want to risk messing it up. Does anyone know a shop in Orange County, CA that has experiences installing these?
Thanks, Jeremy: |
make sure you buy it from 123 ignition usa , then I can help you with the install.
Otherwise I can't help I am the tech master for him ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
Hi Ian. Thank you for your response. Are you located in Orange County, CA? Also, does 123 ignition usa have preprogramed curves for specific models. I know PartsKlassic has these pre-programmed for stock engines along with a wireing harness that looks like it makes it rather seemless. My issue is that having read the threads I don't want to track down issues like changing the coil ect. I would rather have someone set it up.
I know a local shop, just message me.
1976 911 1976 914 1986 951 |
J, do what you like , It's just tough to get help when things go wrong .
Have fun Ian
| Tags |
| 123 ignition , 123ignition , distributor , shop |
