Ignition timing question, CIS vs EFI
When we look at the advance curve from the pre-Motronic era, the advance usually keeps going up, eventually reaches max advance and stays up there until redline (with some exceptions due to vacuum advance or retard).
http://forums.pelicanparts.com/uploa...1681159703.png Now, on the 964 & 993 maps that Steve W shares on his website, we can see that at full throttle, max advance is reached around 3500~4000, and then it goes down. https://www.911chips.com/ignition.htm See at the bottom of the page, the 964 and 993s ignition curves reach around 25 degrees around 3000~3500rpm, then the timing goes down to around 15 degrees and eventually back up to only 17 close to redline. Can someone explain why the curves look like this? Why does the 3.6L need that much more timing at mid-range than high up? Intuitively, it would seem that higher revs would require more advance. |
To continue advance at higher revs may result in detonation.
And don’t forget that 964 and 993 are duel plug so don’t need as much advance…
(digital signal processing) technology to monitor for detonation and retard the timing. |
I'm no motor specialist. All I can say from what I've read over the time - ignition and fuel mapping (if possible, depends on the engine management) is always a compromise between hardware requirements, horsepower, torque, emissions, driveability, fuel economics, temperature management etc.
A leaner mixture tends to knock earlier than a rich mixture. Knocking tend to occur more on lower revs with much load on acceleration than on higher revs. So depending on the fill grade, required time for burning and exhausting the cylinder will force to retard the ignition. The larger the displacement the longer the flame front takes time to burn the gas, that's why bigger and race engines have twin spark ignition. Also there is one specialty on Porsche engines - the valves are bigger than other vendors to let them "breathe" better which gives more torque on lower rpm ranges. That's why the optimal position for the spark plug in the middle of the cylinder head was not possible. And 4 valves per cylinder were too costly and too complex for that type of cylinder heads they were using. Remember - the 959 had water cooled cylinder heads, because of the high cylinder head temperatures. This was also a reason why Porsche decided to move to water cooled engines, beside gas and noise emissions, more power and fuel economy. Thomas |
Principles of Tuning Programmable EFI http://andrewcologne.bplaced.net/911/flamespeed.gif Thats why in ignition maps mixtures at lower/leaner loads will be ignited faster, means with more ignition advance. And thats also why a high "ported vacuum" at the dizzy (which does occur on very low load) needs to be ignited faster where the vacuum unit of the dizzy advances with approx. 5°. It does not burn faster but its combustion will result hotter due more O2, here often exists confusion Quote:
And that's expected, the usual trend for timing is going up (edit) as load decreases, and going up as RPM increases. In this thread, Jamie mentions high timing in deceleration helps engine braking. Quote:
If they used a DSP maybe they can efficiently filter out the noise and get it to work all the time. Without knock control, I could understand the engineers would stay on the safe side, and only push the timing close to the limit when the knock sensor is active. If the mixture gets richer at high revs, it would require less timing as it burns quicker. Maybe a combination of both? I don't think I've seen any other maps with such a reduction in timing from mid to high rpm at full load. |
And in your last paragraph youre mixing up load and RPM, as ... higher load = less advance lower load = more advance Higher rpm = more advance (up to a certain rpm) Lower rpm = less advance Quote:
@AndrewCologne:
https://en.wikipedia.org/wiki/Engine_knocking#:~:text=enriching%20the%20air%E2%8 0%93fuel%20ratio%20which%20alters%20the%20chemical %20reactions%20during%20combustion,%20reduces%20th e%20combustion%20temperature%20and%20increases%20t he%20margin%20to%20detonation Detonation can be prevented by any or all of the following techniques:
I read the opposite: Leaner mixtures burn slowier than stochiometric or richer ones. I did not know that modern direct injection and superchargend engines are more subsceptible than older ones. |
If Porsche achieved to use the knock sensors on the full RPM range, that's great. |
My experience with it is that you run an aircooled motor up with WOT/wastegate open to redline, an abrupt throttle close (eg for the shift) will cause knock detection to "hear" metal-to-metal from the chain/pistons etc for a fraction of a second, no more. Considering it vanishes on the re-application of throttle or when the RPMs drop a bit - and that timing gets pulled when the throttle is already shut, it doesn't seem like much of a problem to me. Some seem to think an aircooled 911 motor is too "noisy" for knock detection, but this would seem to ignore that the factory didn't think so for the 964/993. Works great for me - I've been running it on my 930 for more than a decade and still running it now, with a full EFI (Motec) setup. In preference to Motec knock detection. Quote:
I found that a "sort-of" stock 930 with factory timing will knock around 3000 RPM with load & West Coast premium gas - eg climbing hills on 1/3 throttle in the correct gear. US 930 dizzy advance curve & timing is less aggressive/lower than RoW specs - still knocks & causes the Safeguard to pull timing when climbing hills. I used to have little shiny pockmarks in the carbon on the piston crowns. Haven't had that for a long time now. I some things to be not what I expected once I actually had instrumentation:
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/611409-my-j-s-safeguard-paid-itself-last-week.html Oh, and actually trusting the Safeguard to detect knock & pull timing (after it demonstrated that it did precisely that when my distributor advance plate stuck fully-advanced!) allowed advancing the timing 5-6 degrees over stock (and bleeding the extra off as boost rises to arrive back at factory timing). Could probably have gone much further - but that yielded a very useful improvement in mid-range tractability/response. Looks to me as though the factory ended up leaving a lot on the table, timing-wise, for safety. It's kind of amazing to me that CIS cars run as well as they do, TBH... Those guys at the factory really knew their stuff. |
Remember when removing the feet from the gas pedal at higher revs where the mixture at deaccelerating suddenly leans out and the spark isn't fast enough to fully ignite the mixture in the cylinder so it makes the popping exhaust sound. That's why. Other fact: If connecting the retard vacuum hose on a 3.0 US 930.16 engine like used as factory default, you MUST check the deceleration valve for proper working, so it adds "metered" air to the manifold. If not and with such an retarded ignition timing in combination with a closed throttle at such high revs and such an upcoming high vacuum in the manifold, this will lean out the mixture significantly and a huge popping sound will come out of the tail pipe Quote:
which typically is not the case for most all aftermarket engine builds, e.g. using MoTech. A DSP chip such as the TMS320 can provide the necessary processor power once the time domain data (knock sensor signals) are converted to the frequency domain for processing. The 964 DME ECM used a separate chip (Motorola 6800 - 8 bit) for knock control, where the 993 DME ECM had that function integrated into the main Intel processor. |
Let's not forget that the mechanical distributor cannot bring the advance back down due to the way it works (weights 'thrown' out with centrifugal force).
Even on older engines, there is a an advantage to more advance in the mid-range. Using electronic advance, I've seen an RS motor take 45 degrees 'on cam' without knocking, falling to 36 at high RPM to avoid detonation. |
With vacuum signal hooked up, I have a 123 distributor set up to advance to 47 degrees at lower rpm’s with light load, as RPMs and load increase the MAP timing is backed out.
There are two curves one is determined by RPM’s and the other by MAP/ vacuum. |
Would you share the curves / files with us? 47degrees adv sounds pretty heavy. Do you used a knocking tool? Which gas? Is the engine still stock? Thomas |
My RS example above of 45 degrees was WOT on a dyne with full monitoring of knock so quite impressive but not for the tinkerers without monitoring equipment! |
This is a great discussion about timing. Let me add that more timing is not necessarily a good thing. I gotta wonder about 47 degrees of advance.
I can't speak about the advance curves in the Motronic and later EFI systems, as I still run CIS. ;) However, there is point where too much advance loses power and increases tendency to detonation. That typically has to be determined on a dyno at a range of RPMs and loads, and that's how the factory or performance tuners figure out the basic advance maps. Then the knock sensing backs off that timing if knock is detected. That's how engine computers compensate for lower octane fuel or high temperatures, or other deviations from ideal. |
The "tricky" thing is, that many 123 users do simply use the known "ported" vacuum connection which leads to the dizzy. And here this gives a total wrong signal as ported vacuum is only available at a slightly open throttle. With this kind of vacuum you will never get the whole "common" MAP vacuum range needed for a proper timing at "all loads".
So ... to get a full MAP signal ... For 911 SC till '79 without ECU this is the same vacuum line like connected to the WUR. For 911 SC from '80 with ECU its the same vacuum line connected to the cruise control and deaccel. valve. |
Fo completion here's a link to the SWCchips website, they have pictured the curves from the 3.2 Carrera up to 993 https://www.swchips.com/ignition.htm Thomas |
| All times are GMT -8. The time now is 12:12 PM. |
