915 stuck in reverse, help needed
I have just reinstalled the engine and transmission in to my 72 after some engine out work. I have replaced the shift fork seal at the bottom and in shift shaft input seal among other stuff.
Now the 915 is stuck in reverse and I can not access the 5th-reverse plane. It sort of shifts in to 1-2-3-4 but feels odd. I have not started the engine nor driven it. I was pretty careful not to move anything when replacing the shift fork seal. I have studied the various threads related to this topic, but has not been able to find a situation exactly like mine. Thanks for any feedback Is this as simple as the reverse light shift thing or something more serious😳 |
Sounds like the alignment of the shifter when bolted to the selector shaft is a tad off?
So what happens when you put it in 1-4 gear and try to let the clutch out, if the engine stalls it is stuck in two gears at the same time. If it still moves in reverse than it sounds like you may have a problem with the shifter bushings or the shift coupler bushings or basic adjustment.
More info will help in a diagnosis. I see you are saying that you have not started the engine, how do you know it is stuck in reverse ? Richard |
I had this happen when I didn't have the shift rod secured properly and was out of alignment. After I selected reverse it got stuck there and had the same symptoms; I could row through 1-4 but getting into 5-R was difficult and any gear selected while running resulted in reverse and stalling.
Lift up the rear wheels off the ground to take the tension off the box and try to reset the shift rod at the front or the coupler as necessary. My issue was at the front as that was where I had worked prior. |
Thanks for the replies.
The transmission shifted flawless before I dropped the engine and the shift coupler was removed from the shaft using he set screw, i.e. no changes has been made to the shifter adjustment. I have removed the shifter fork and checked the alignment of the 1-2 and 3-4 shifter shafts OK. The 5-reverse shaft is pushed all the way forward, as in reverse engaged. And I tried to roll the car and the engine tries to turn clockwise when pushed back. Sp reverse it is. Depressing the clutch and moving through the gears makes no difference. I can not move the shifter to the 5-reverse plane. I have no idea to how this has happened with the transmission out of the car and no internal movements. It was stored upright with the bell housing down, but how would that screw up the box? I will start checking the reverse light contact pin. |
Push the pin in. Has the trans been apart in the past?
There is no obvious signs of a previous rebuild, but I can’t tell for sure. |
Grab the plug in the pic with a small pair of channel locks and twist back and forth while pushing up, they usually are not real tight as it is just a interference fit If in doubt stick a slim magnet down the bore and if you come out with a lockout pin then that is a no-go, this will allow the trans to be in two gears at the same time. Not saying this is your problem but it fairly easy to check and one more diagnosis to confirm or eliminate. Richard http://forums.pelicanparts.com/uploa...1681414013.jpg http://forums.pelicanparts.com/uploa...1681414013.jpg |
Ditto what Mike said. If it worked fine before you dropped the transmission, I would look very carefully at the alignment of the coupling and shifter. Did you do anything to the shifter while the tranny was out? Any possibility that the shaft going into the tranny got bent while removing or installing? Try this: Undo the coupler at the set screw and pull the long shift rod out of the way. See if you can shift the transmission manually from the shift shaft alone. Try rolling the car back and forth while shifting too.
Solved!,
Pressing the reverse switch pin did the trick. And it was surprisingly easy. My 2 cents : drain the gearbox oil, support the transmission with a jack, remove the transmission mount, remove the speedo cable, undo and remove the reverse switch (22 mm ring spanner), remove the pin using a magnet, insert a 4 mm drill bit (shaft side inwards) , place a small block of wood on the chassis and use a small prybar to push in the drill bit. My drill bit was approx. 80 mm in length and protrudes out of the gearbox allowing the trick with the prybar. The only tricky bit was inserting the wires in to the switch. Lesson learned: keep the transmission in neutral when removing and installing! Thanks all. |
I ended up taking the drivetrain out again, front cover off the transmission and popped it back out of reverse. Didn't think of the switch pin, brilliant. |
Gotta remember that too.
ok... what stops it from happening again?
Should be in every engine drop check list......"keep the transmission in neutral when removing and installing....."
OP's shifter rod must have moved when he replaced the shift fork seal |
Here's a pic of exactly where the shift rod arm/lever should be when the fork is out and you are replacing the seal.
You can manually manipulate the rod to get things back like this before you reset the fork in there. Get it right! http://forums.pelicanparts.com/uploa...1681578171.jpg When you set the plate w fork back in, make sure you straddle the arm/lever. http://forums.pelicanparts.com/uploa...1681578320.jpg |
I don't think I have tried to put the tranny in neutral when pulling the engine or the engine and tranny as a unit. Typically I put it in 1st or 3d because that moves the rod which sticks out of the tranny the farthest back into the tranny. Less sticking out means less to hang up on the exit of the center tunnel.
The reason getting stuck in reverse is relatively common. You can see from the nice photos looking up into the 1 through 4 gear shifting stuff that the dongle is between one or the other pair of ears for 1/2 and 3/4. When in 5/reverse, the dongle tip is past both of these, so it just sort of rattles around when you are selecting 5 or reverse. 5/rev is selected by the small finger which extends sideways from the main shift rod within the nose piece space. Moving the shifter to the 5/R plane engages that finger into a shallow slot on the rod which moves the forks whatnot to engage 5 or rev. Compared to the other 4 gears this is a far less robust connection. For instance, while at a stop in reverse (worse, while still rolling backward in reverse) and yanking it into first)can allow the finger to get out of its slot. Now you are in reverse, and can't get out of it. You might think you could force the finger to slide along that rod and get back into the slot, but perhaps the other lockout systems prevent that? Luckily, the backup light works by the 5/R rod end moving toward the front of the car when going into reverse. So the rod hits the end of a pin which then closes the backup light switch. Hence the trick of moving that rod back into place by pushing on the switch pin, or using a thin rod to push, allowing the finger to drop into its slot. When out of its slot it is sliding along the smooth surface of the nose piece shift rod. http://forums.pelicanparts.com/uploa...1681607048.jpg 1/1 is the main shifter rod - the one which sticks out the nose piece. #2 is the dongle, inside the main case, with the fork piece #6 below it, which serves as a fulcrum for the dongle. The red dot shows the "finger" which does the 5/R shifting. #19 is the shift rod for 5/R, though alas it doesn't show the shallow slot ground into it which engages the finger. Typically, to remove the transmission one would undo the grub screw holding the external shift coupler to to the transmission main shift rod. When reattaching the coupler, you'd just tighten the coupler screw into the hole on the shaft, and need no adjustment. If you took the coupler off the shaft going forward to the shift lever, then you might not get things back where they were, and if you get it wrong rotationally, you might end up with the "finger" not pressed fully into its slot. This is all easier to understand if one has had the nose piece off at some point and seen how things work in there. I couldn't find a picture in my collection of that. Didn't take John but a millisecond to guess what may have happened and how to fix it. I tend to get carried away with the "why." |
Hi Walt. I have the nose piece off one, waiting for a new staked nut. Anyhow, here are a couple of photos illustrating what you said. The shift rod is engaged in the reverse/5th notch. https://i.postimg.cc/VsZPXc8g/IMG_20..._095634901.jpg https://i.postimg.cc/gkwFDBcW/IMG_20..._095800732.jpg |
| All times are GMT -8. The time now is 11:02 PM. |
