Looking to buy a 911 Correra 4
I found a 2000 locally at a dealer.He does not know as much as I do about them so that’s not much! While looking up thing’s wondering if there is any other names it goes by such as the engine #?
I’d like to particularly know the name of this engine & can I find out if the bearing was replaced because it was supposed to have been replaced along with the transmission @ 116,000 miles. It now has 156,000. Thanks! |
996 Porsche 911s use the M96 Porsche engine. The M96 engines have a well known issue with the IMS bearing. If you Google for '996 IMS' you will find tons of information. I do not believe there is a way to confirm that the IMS bearing was replaced without removing the engine or transmission from the car to visually inspect the IMS...but then I am not a 996 expert and you should confirm this for yourself. You might also check out the Pelican forum that is specifically for 996 Porsches here: https://forums.pelicanparts.com/porsche-996-997-991-forum/ Last edited by ErrorMargin; 01-28-2025 at 04:44 PM.. |
Thank you sir!
May be books like this are a good entry point...
https://porschecarshistory.com/wp-content/old/biblio5/27/Original%20Porsche%20911%201964-1998%20by%20Peter%20Morgan.pdf There are also some buyers guides available. Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL. |
