Question on rear deck lid hinge spacers
Was working on the AC system and noticed a bolt missing on my deck lid hinge.
1984 911 Targa with AC.
Looking closer I noticed that there were a couple shims on the front bolt between the deck lid and the hinge on the passenger side. On the driver side there is only one shim in the front.
There are a number of issues I've run into this car where things are not quite right after it was put back together after the paint job.
Does anyone know what the correct shims should be for the hinges?
Is it trial and error until I get a good fit?
Old 10-13-2023, 12:06 PM
I think it is trial and error, because IIRC the PET does not mention number of shims required or mentions something like "as necessary".
Gilles
RoW 88 Carrera coupé
Old 10-13-2023, 12:10 PM
romster's Avatar
As necessary indeed. They don't match up in mine either, yet the lid is fitted as perfect as can be.
Old 10-13-2023, 02:06 PM
PCA Member since 1988
If it fits well as-is, DON'T TOUCH IT!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-13-2023, 02:29 PM
Understood, but I at least have to add that 4th bolt.
Which likely means it needs a shim or 2 to match the current gap. Though I dont know if that gap stays when its closed.
Old 10-13-2023, 02:43 PM
nene's Avatar
I would add a shim and the bolt then close the lid. Adjust as needed.
Serge
Old 10-13-2023, 02:48 PM
I have the shins - one under each hinge at the top. Looks to keep lid aligned perfectly with the roofline and side to side.
Old 10-13-2023, 03:38 PM
