Fuel Pump Cap Nut Torque
Can’t find it in my Bentley, or the PP How-To.
Is there a torque spec for the fuel pump cap nut, or just tighten til you feel the washers crush?
Old 03-21-2021, 02:54 AM
1985 Carrera
Anyone know this? Ive read 14 ft lbs. Can anyone confirm this? I dont want to over tighten.
Old 04-19-2023, 01:46 AM
From another thread:
Torque for the hollow fuel bolts.
M8, Small ones on top of injectors and fuel dist. 7-9 ft lb.
M10, Only one on top of the warm up regulator with a smaller #8 9-11 ft lb.
M12, Fuel filter, and larger on side of the fuel distributor. 14-17 ft lb.
M12 Cap nut, Dome nut on top of new style fuel pump 11-14 ft lb.
M14 Cap nut, 18-22 ft lb.
Torque Setting for Hollow Screws on Fuel Distributor
Old 04-19-2023, 05:54 AM
PCA Member since 1988
14 seems excessive to me for what it does. Tighten it enough that it doesn't leak, plus a little bit more. Don't squish the crush washer.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-19-2023, 04:29 PM
I posted the torque items but I do what PeteKZ does, I used new copper washers on my new pump and tightened them down by feel, snug with an extra small oomph. No Issues. Ive also read 12 lbs but that seems high also for that cap nut on the banjo bolt.
Old 04-19-2023, 07:31 PM
