cut red wire out of tail light wire harness
I bought a BaT car, 1984 911 Targa that has a few wires that lead to nowhere.
Tail light wire on each side has a red wire coming out of it that is just cut off. Any ideas what these wires were for? Could this be some old alarm system wire?
Just tape them off and leave them be?
thanks
Old 04-12-2023, 12:40 PM
proporsche's Avatar
it is not an original wire get rid of it..remove the el.tape and you will see more
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-12-2023, 03:27 PM
maybe for old alarm to flash lights
Old 04-12-2023, 03:56 PM
I had not thought of that, but I think you are spot on
Old 04-12-2023, 04:09 PM
Before you clip decide if you want to run a third brake light. If they connect to the brake light you can connect into that. Test it with meter with brake press, ignition on and see what happens. I just put a third brake light in a 1984 targa.
Old 04-12-2023, 06:31 PM
Thanks for that idea.
This car already has a 3rd brake light so I dont need to tie into anything.
I guess I need to get out the volt meter and see what that wire is connected to.
Old 04-13-2023, 12:56 PM
proporsche's Avatar
just remove the tape ..take a picture and we will tell you where it is connected to;-)
Ivan
Old 04-13-2023, 02:41 PM
Oh boy.
I took off the red wire and unearthed this mess.
I've seen hack jobs in my day, but this is unbelievable
All of the wires in this harness are nicked and they they were covered in electrical tape. The harness must have come lose and rubbed against something like the air conditioner pulley, or maybe there was a nasty short somewhere.
The attachment of the red wire is just plaid bad.
So its time to fix this. I assume the other side is just as bad.
I guess its time to cut all the wires, solder or crimp them and cover with a good heat shrink tubing.
Any recommendations on the best way to fix this?
Time to order a bunch of stuff I guess.
Old 04-15-2023, 12:33 PM
proporsche's Avatar
yup very ugly work.Fix your wires correctly-as you said cut it and solder together. .This one was for 3rd brake light
Ivan
Old 04-15-2023, 12:36 PM
Been here a while
You’ll get plenty of opinions. Soldering isn’t ideal in high vibration applications.
I’d crimp and shrink-tubing these using a Crimp similar to a bmw part like this.
BMW-61138353746, also available in larger sizes by swapping the last 6 for a 7 or 8
I’ve bought them from FCP euro.
www. Put Fcp euro’s domain here /products/bmw-cable-connector-61138353746
looking for 1972 911t motor XR584, S/N 6121622
Old 04-15-2023, 01:58 PM
Either use duraseal solderless connectors or "Parallel Connectors" and "Raychem SCL" shrink tubing for a lasting repair.
Soldering is inferior to crimping.
Old 04-15-2023, 06:44 PM
ROW '78 911 Targa
timmy2's Avatar
Get this kit and a set of open barrel crimpers and some adhesive lined 3:1 1/8” heat shrink.
Tnisesm 550 Pcs Open Barrel Crimp Terminals, U Shape Copper Ring Terminals Crimp Kits - Non-Insulated Assortment Cable Wire Spade Electric Butt Connector Kit https://a.co/d/1uVi8EZ
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-15-2023, 10:23 PM
Fixed the mess.
Threw an old sheet over the engine to catch all the small pieces of cut wire. Cut all the wires, striped them, crimped on a bullet connector, then heat shrink each one, and then a large heat shrink in the entire bundle
The other side only had 1 wire that had to be repaired.
Much better than before
Well, I think it is anyway.
Old 04-21-2023, 02:16 PM
