Eva
911SauCy's Avatar
'78 SC Fuel Filter Woes...
Coming out of the garage, absolutely fuming... A month wasted, 3 orders, and now returns later... I've still not been able to get a Fuel Filter for my '78 Targa that is correct...
The outgoing
...which is NLA.
I've not successfully found one here, I've ordered the "replacement" Bosch from FCP Euro, ECS Tuning, and then had a friend (shop owner) order what he was told was the proper replacement, delivered to his shop. All incorrect... Closest thus far was a Bosch 0-450-905-021 ....yet the outlet fitting size is incorrect.
I believe I've found the most like (visually) replacement on SunCoast 0-450-905-079 so this will be the 4th attempt....
If anyone has any information or experienced the same and has insight into what the proper resolution was, that would be greatly appreciated.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 04-08-2023, 02:06 PM
7783911's Avatar
I searched the internet with the bosch part number and found on e-bay for 20$ just 2 months ago
What is your number (should be same as mine)
1977 911-S Modified (3.0 SC Motor/Flares)
Old 04-08-2023, 03:08 PM
When I faced the same issue, I found that Pelican sold the two adapters I needed:
Fuel Filter Fitting (14 X 14 mm) Part #: 930-110-198-00-OEM
Fuel Filter Fitting (12 X 16 mm) Part #: 930-110-199-00-OEM
These are the inlet and outlet couplers needed to use the 021 fuel filter.
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 04-08-2023, 03:43 PM
Bosch Fuel Filter Inlet/Outlet Fittings..........
These information might help you guys.
Bosch FF................003.............016............0 21...........079
INLET (mm)...........14...............14..............14 ............14
OUTLET (mmm.......14...............14..............12.... ........12
PITCH (mm)..........1.5 for all.
You will need a 12/14 mm x 1.5 mm adaptor.
Old 04-08-2023, 03:49 PM
003 superceeds the 016.
206 637 4071
Old 04-08-2023, 03:53 PM
PCA Member since 1988
On my next fuel filter change, I will switch to the filter from the Carreras. It's used across many more models and is more easily available, including at local FLAPS.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-08-2023, 11:43 PM
HarryD's Avatar
FWIW, all that is different are the fitting on the filter. Just reuse the old ones.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-09-2023, 10:50 AM
proporsche's Avatar
i think they do not match on the filter threads and size-the fittings..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 04-09-2023, 11:09 AM
HarryD's Avatar
Ivan
See if you have an old filter in your stash. I have a pile of them to allow me to adapt what I get to what I have.
I have made a habit of saving the fittings as they do not go bad and are handy for things like this. At most, all I need a new is a crush washer.
Harry
2020 MB E350 4Matic
Old 04-09-2023, 11:17 AM
Unfortunately that doesn't work for those of us without a stash. And the statement that you can use the fittings from the old one is wrong - you need both of the ones I posted earlier to fit the 021 filter which replaces the 016.
Old 04-09-2023, 03:44 PM
HarryD's Avatar
Understood. I was just saying that if you have some older parts laying around, they may be able to rescue you. I have had to deal with this issue for years since the 1973.5 fuel filter became NLA. I always need to McGyver something for the one I am able to get.
Harry
2020 MB E350 4Matic
Old 04-09-2023, 03:58 PM
Eva
911SauCy's Avatar
Thank you for the information on the fittings guys!
I understand that it would work if I had the fittings or the synapse ammunition to be able to determine the required fitting sizes.
Hardware knowledge is the 1 place I really am weak and need to educate myself. So many of you guys on here can look at a nut or bolt and be like, yeah... that's the aurora borealis 2.38mm.
I will eventually get there as I don't want my car to end up a bitsa car years down the road... Bitsa this and bitsa that... ya know.
Fingers crossed the SunCoast Piece will be a direct replacement with the hardware.
Old 04-09-2023, 04:03 PM
HarryD's Avatar
Find a local place that serves the hot rod community or a place that makes hydraulic hoses. Bring the new filter you have and the old one. Explain the problem. They mAy have the fitting or can braze one from the parts you have.
Harry
2020 MB E350 4Matic
Old 04-09-2023, 04:29 PM
Still here
pmax's Avatar
How about posting more info on what you ordered, pics, part numbers will be great so others can be spared this mental exercise ?
Old 04-09-2023, 05:26 PM
Eva
911SauCy's Avatar
In the OP
"I believe I've found the most like (visually) replacement on SunCoast 0-450-905-079 so this will be the 4th attempt...."
Picture on their website is quite stubborn, but looks like the outgoing, just different number
Old 04-10-2023, 05:29 AM
I literally posted the part numbers from Pelican!
Old 04-10-2023, 06:20 AM
Full Send Society
Nor for nothing and I believe others have mentioned similar- Belmetetric has all the fittings and adapters you need to make just about anything work.
https://belmetric.com/fittings-plugs/
Tony posted the threads for various fuel filters above, it’s pretty simple to figure out what you need.
I had trouble with my old CIS testing gauge kit not fitting my car and a few $10 adapters solved it.
Get a thread gauge like this as they’re just good to have in the garage, and then buy the adapters.
Nut & Bolt Thread Checker - 26 Male/Female Gauges - 14 Inch & 12 Metric for Quickly Checking Nuts and Bolts Inch or Metric and Verifying The Size https://a.co/d/h5q6Dzy
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 04-10-2023, 06:37 AM
proporsche's Avatar
yup exactly the same here ..i always kept all the fittings
Ivan
Old 04-10-2023, 11:12 AM
I encountered this when I replaced my filter last fall - took the new filter, along with the old one and its fitting, to a local hydraulic shop that matched the threads on the new filter and the outlet on the old fitting.
'80 SC Targa
Avondale, Chicago, IL
Old 04-11-2023, 09:38 AM
7783911's Avatar
I found a bosch 0 450 905 014 on ebay for 20$ its in my spares kit
Old 04-12-2023, 12:22 PM
