jpgroth's Avatar
Fuel Filter Thread Sizes
Can anyone confirm what the thread sizes are on this fuel filter?
930-110-196-00-M14.. Bosch PN 0450905021
Josh
@joshgrowth
Old 04-23-2023, 11:49 AM
Here's what you need for the 021:
Fuel Filter Fitting (14 X 14 mm) Part #: 930-110-198-00-OEM
Fuel Filter Fitting (12 X 16 mm) Part #: 930-110-199-00-OEM
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 04-23-2023, 12:14 PM
jpgroth's Avatar
Thank you JR. Do you know which side of the 12 x 16 threads into the filter? I’m running AN lines and am converting to banjo fittings. M14 x 1.5 and M16 x 1.5?
Josh
@joshgrowth
Old 04-23-2023, 03:05 PM
Bosch Fuel Filter -021………
Josh,
Bosch Fuel Filter #021 has 14-mm inlet and 12-mm outlet both 1.5 mm pitch thread.
Tony
Old 04-23-2023, 04:00 PM
jpgroth's Avatar
Awesome, thank you Tony
Josh
@joshgrowth
Old 04-23-2023, 04:33 PM
HarryD's Avatar
This post by Tony some good info:
Originally Posted by boyt911sc View Post
These information might help you guys.
Bosch FF................003.............016............0 21...........079
INLET (mm)...........14...............14..............14 ............14
OUTLET (mmm.......14...............14..............12.... ........12
PITCH (mm)..........1.5 for all.
You will need a 12/14 mm x 1.5 mm adaptor.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-23-2023, 04:41 PM
