-   -   911 SC, is there a way to delete the factory oil filter? (http://forums.pelicanparts.com/porsche-911-technical-forum/1138650-911-sc-there-way-delete-factory-oil-filter.html)
-Levi- 04-21-2023 10:23 PM
Are there any kits or ways to remove (bypass) the factory 911 sc oil filter?
I have no need for the filter and would like to reduce weight and clean up my engine bay.
Thanks in advance
winders 04-21-2023 11:32 PM
Just out of curiosity, why do you think you don’t need the Factory filter?
-Levi- 04-22-2023 07:41 AM
I have a 3.6 conversion, the 993 engine has a filter and the sc body has a filter. I have no need for two
3literpwr 04-22-2023 08:07 AM
Outside of replacing the tank, i'd say keeping a filter is the easier way to go. Double filtration is not an issue I guess.
dannobee 04-22-2023 08:09 AM
993's have two oil filters, one on the engine and one on the oil tank.
winders 04-22-2023 11:27 AM
Actually, you do need two. The one on the engine is on the pressure side and the one on the tank is on the return side. You really want both. The 993 came from Porsche with two oil filters.
-Levi- 04-22-2023 07:51 PM
Thanks for the info everyone. 2 it is
