1973 2.4t
Hi,
I have a 73T that I use regularly, it's time for a new battery. A previous owner changed the set up for a single battery in the front hatch.
Does anyone have any suggestions for a single 12v battery to use?
Currently using a 12V 74Ah 680CCA, not really sure if this is an acceptable spec.
Many thanks
Mark
Old 02-19-2025, 09:14 AM
HarryD's Avatar
I use an Optima red top on its side. There are tons of threads on this topic. Use the search function here to find them.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 02-19-2025, 12:03 PM
PCA Member since 1988
I also have a 1973.5T. I use a Group 70 AGM from NAPA in the RIGHT battery box only (it just barely fits). I figure putting it on the right side helps balance the weight of my ass in the drivers seat, and also gets it away from the fuse panels. It's a GM style side-post battery, so I use the screw-in adapters to fit the standard clamps in the 911. No problem at all cranking the engine. 5-1/2 years on it so far.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-19-2025, 03:23 PM
Thanks for the replys everyone, much appreciated!!
Old 02-20-2025, 01:03 PM
