-   -   Removing rear reflector - quick question (http://forums.pelicanparts.com/porsche-911-technical-forum/1138668-removing-rear-reflector-quick-question.html)
ramonesfreak 04-22-2023 09:01 AM
Gotta repair mine. I know the procedure but have delayed repairing reflector correctly by removing it from car
my fear is those metal tabs that i have to bend
is there a real risk of breaking them? dont think my reflector has been off so tabs likely have never been bent before
I assume I just bend them back prior to reinstalling and then push the reflector back on. Will the plastic mounting bracket parts (not sure what to call them ) go back in tightly without much fuss? I’m worried I’ll never get this back on so it’s factory tight and it will either look uneven or fall off as I’m driving
thanks
Car is a 1983
Dpmulvan 04-22-2023 10:35 AM
Access the reflector from the bottom (shield) think there’s like 8 screws to remove, then carefully pry them off and re bend them upon install.
