How To Test Your Back-up Lights and Switch Insitu…..
If your back-lights are not working when you put your transmission to reverse, there are several reasons that could cause this problem, namely:
To deal with this problem, you need to test terminals #5 and #6 for the T14 wire connector located in the engine bay. At the left side of the engine bay is where the fuse panel is located under a plastic protective cover. Remove the black plastic cover and you will find the 14-pin connector. If you have not separated a 14-pin (male/female) connector before, be aware that the 40-year plus old plastic material would be brittle and could break easily unless you have a new one. So handle this job cautiously with tender loving care. And take some pictures just in case something happens unexpectedly. First step is to get access to the 14-pin connector in the engine bay. Picture #1: http://forums.pelicanparts.com/uploa...1682191284.jpg Picture #2: The 14-pin connector is now accessible. http://forums.pelicanparts.com/uploa...1682191618.jpg Picture #3: With ignition switch @ OFF position, only pin #14 has power. Terminal #14 is HOT all the time unless you disable the battery. But we need power to do the test. I was using an awl or an ice pick to separate the female plug from the male plug (T14 connector). http://forums.pelicanparts.com/uploa...1682191654.jpg Picture #4: The #5 and #6 pins are shown below. If you zoom the picture below, the pins are individually numbered. Odd numbers (1~13) bottom row and even numbers (2~14) top row. http://forums.pelicanparts.com/uploa...1682191654.jpg Picture #5: When ignition switch is OFF, pin #5 has NO POWER. When you switch the ignition switch to ON position (not start) pin #5 is energized (power is present). So bridging pin #5 and #6 is same as bridging the back-up switch terminals. And the back-up lights lit up with the transmission in NEUTRAL. TEST RESULT: Wiring and light bulbs confirmed good and working. http://forums.pelicanparts.com/uploa...1682191699.jpg Please note I was using a motor with 915 transmission for this demonstration and tested the back-up lights and switch with ignition switch ON. Both lights and reverse switch confirmed good and working. Before using the jumper wire, I had the ignition @ ON, gear in NEUTRAL, back-up lights OFF, and finally bridged #5 and #6…………….both back-up lights (diver side and passer side) LIT UP! Remember that the gear is in NEUTRAL. So what have we achieved? We have demonstrated that the wiring and the back-up lights are good and working without using the back-up switch. Unfortunately, I don’t have any defective BACK-UP SWITCH to test. Next project is to test a defective back-up switch and transmission push pin. Tony |
| All times are GMT -8. The time now is 07:38 AM. |
