HarryD's Avatar
Missing Protective Cover
Today, I was under the front of my car. I saw this at the end of the driver side front torsion bar:
It should look like this:
Per the PET, it is a Protective Cover.
I am thinking that I can clean up the rust as best I can and weld a small plate in the area to allow me to attach a Protective Cover.
Thoughts?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-03-2023, 08:26 PM
Looks like you need a new suspension pan. The rust is probably much worse than you can see.
Old 05-03-2023, 08:32 PM
HarryD's Avatar
My first thought as well. I probed around with a screwdriver. Seems to be pretty localized to the area.
I have seen worse on my 1970 Bus. Cut away the bad, weld in new.
Harry
2020 MB E350 4Matic
Old 05-03-2023, 08:45 PM
PCA Member since 1988
Ditto. I can almost guarantee the rust is more extensive/expensive than you think.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-03-2023, 10:19 PM
Still here
pmax's Avatar
Good thing it didn't give way when there's a jack stand under it !
Old 05-04-2023, 09:07 PM
HarryD's Avatar
True. But it was already gone when I looked. I usually use the pinch joint behind the wheel.
Harry
2020 MB E350 4Matic
Old 05-04-2023, 09:21 PM
