| PeteKz |
05-03-2023 04:20 PM |
The fuel delivery may be significantly off, even if you replaced the injectors. And even though you got new injectors, no guarantees that the patterns are good, although they most likely are. In your car, you can adjust the delivery to be exactly the same on all 6 injectors because your FD has adjustment screws on top of it next to each banjo bolt. To do the test, you pull out all 6 injectors, leaving them attached to the lines. Put each one into a measuring cup or test tube or such, then run the pump and lift the air sensor arm to various heights, observing the patterns. Then make sure they deliver the same amount of fuel.
Re AAV and AAR, I just took mine off and left them off, and the decel valve too. But I have a hand throttle, so I can manually increase the throttle during warm up. Not having that plumbing in the way makes access to the TOD a lot easier too.
