911SC Air Injection Port Plugs?
I've heard that Mercedes Benz makes a drain plug? to fit the
ports when the air injection jets are removed from the cylinder heads. Does anyone know the part# or any other options for plugging the ports? |
i bought mine from www.type911.co.uk for 1£ a piece. I think Pelican carries them too. it's 10mm plug with 1mm thread pitch.
Thank you for your time, |
i recently purchased a porsche so im still learning about all the tweeks for them. i have an 82sc. why would someone plug the air injection ports?
The ports in question are the ones that pump fresh air into the exhaust to meet emission requirements. The smog pump (usually found on left side of engine bay) is next to useless in most parts of the world and just takes up space. People remove it (like me) and plug the ports.
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Jerry M '78 SC |
This link should have most of the info you need.
SC owners: Pros/Cons of removing Air Pump Here is the link to Pelican Parts listing. $5 each. Support our host! http://www.pelicanparts.com/catalog/shopcart/9144/por_9144_brakes_main.htm |
Jerry M '78 SC |
More useful info, thanx. this bulletin board is great -- im gonna be spending a lot of time on here.
Somewhere in the Midwest
I picked up some plugs at NAPA! Metric..I'll look it up as to the size I bought.
I bought a set a couple of years back when I had an SC from my local metric hardware supplier. They are actually "set screws" . Of course, living in Canada makes gettting metric stuff rather easy.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
My -81 German 930 had air-pump. This gentleman is based in Italy (Aviano airbase) so i guess he bought Italian-sourced car. As far as i remember, Italy didn't mandate cat-converters until early 90's so his car doesn't have O2 sensor! Weird but true. For instance, 911's sold in Sweden got their O2 sensors first in 84' with Carreras.
![]() Jerry M '78 SC |
Thanks for the help. After searching several hardware and auto parts stores in NW Ohio, I ordered the 914 brake caliper plugs from Pelican (support the host!). My SSI HX upgrade has turned out to quite an adventure.
where would the pump be on my 82 911sc (euro) if i had one?
Jerry M '78 SC |
This is the only pic I can find of my pump still attached.
And this is where the small plugs will eventuall end up. All of the pipework has to be removed.
A 1/8'' NPT Brass Plumbing plug works perfectly, and you can pick them up at any hardware store.
Doug Crossman #92 1992 964 PCA G class #902 1979 911 PCA 911 Cup 96 993 Targa |
I believe these are 10 x 1.0 metric straight threads; an 1/8" NPT pipe plug (.397" to .390" major diameter and 27 threads per inch) will likely go in (assemble) but will deform the threads in the aluminum head.
Jim
do the air injectors come out easily? I was thinking about drenching mine with a little penetrating oil for a couple of days (not that penetrating oil works it just makes me feel better) then take a crack at them.
does the 1/8" NPT plug thread in nicely or does it just maul it's way in? I'd hate to ruin the threads on the heads. If emmissions testing comes to my area It would really hurt.
big AL '77 911 |
