77 911S pulley bolt socket size
All
I could never turn over the engine using the fan pulley as all tutorials I’ve seen suggest for doing maintenance like valve adjustment. I’ve always used the crank bolt using a standard wrench (can’t fit a socket in that tight space). Looking for the proper metric size wrench now, is it 19mm ?
Tony
Old 05-06-2023, 03:06 PM
HarryD's Avatar
It should be a M12 bolts with a 18 or 19 mm head.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-06-2023, 07:19 PM
Originally Posted by tonyduc View Post
All
Tony
I don’t recall the size head on crank pulley but I’ve had luck rotating the engine using the fan pulley when I use my hand to temporarily add belt tension.
I’m using the special tool on the fan and not tightening the alternator nut.
Old 05-07-2023, 09:23 AM
Thanks all. I asked because I was at a swap meet and found some long type metric wrenches, so I bought both an 18 and 19, and found that it’s the 19mm that fits.
Old 05-07-2023, 03:51 PM
