-   -   Anyone know where this is supposed to plug into? (http://forums.pelicanparts.com/porsche-911-technical-forum/1139525-anyone-know-where-supposed-plug-into.html)
maverck 05-06-2023 12:18 PM
As I bring my new to me '81 SC out of hibernation I am starting to clean up the engine bay a bit - and I noticed this plug. It was laying down by the red square on the left side of the motor. The other end just connects to a bolt so I am thinking it is some sort of ground.
Anyone know what this is for? And yes, after the photo I spent about 30 mins removing all of the wire loom from everything!!!
Thanks in advance for any help.
http://forums.pelicanparts.com/uploa...1683400657.jpg
Damon88 05-06-2023 12:25 PM
Looks like the plug for the oxygen sensor. Have a look on your exhaust and see if the oxygen sensor is unplugged
proporsche 05-06-2023 12:30 PM
it is you oxygen sensor plug it goes here..i however i always prefer not to plug it in..Your male connector however seems to be broken http://forums.pelicanparts.com/uploa...1683401266.jpg
maverck 05-06-2023 12:32 PM
Thanks! Well I suppose that is why it is not plugged in eh?!
Why do you prefer not to plug it in?
proporsche 05-06-2023 12:41 PM
most of the 911 models around the whole world do not use this at all it takes power off. It is for smog test..purposes..unless you are in CA no need for it..i see in your case you have already some modifications done to your engine..
Ivan
boyt911sc 05-06-2023 02:06 PM
Strange Looking WUR………..
Maverck,
What is the Bosch ID # (1-438-140-XYZ) on your WUR? It looks different than I see on SC’s. Thanks.
Tony
maverck 05-06-2023 06:58 PM
Originally Posted by boyt911sc (Post 11992478)
Maverck,
Tony
To be honest no idea! The car is newer to me and my first air cooled. In the early stages of sorting and figuring out what the previous owners have done.
Ian Comerford 05-06-2023 10:58 PM
It’s worth following up on Tony’s question as he knows WURs as well as anyone and it may help the car run better
PeteKz 05-07-2023 01:29 AM
Maverck, look on the top of the WUR, just to the left of the vacuum hose going out the top. There should be 3 digits stamped there, something like 045, or 033, or 089, or some such.
maverck 05-07-2023 05:26 AM
Maverck,
Tony
086? That right?
Certainly missing the vacuum hose. Let me know if you have any advice seeing this.
And thanks all for the comments / help!!
http://forums.pelicanparts.com/uploa...1683462334.jpg
boyt911sc 05-07-2023 06:44 AM
Nope……..
086/980 is the cast #, right above the cast # are the last 3 digits (stamped). Use a wire brush to clean the surface area and read the numbers (0 483 140 XYZ). Keep us posted. Thanks.
Tony
maverck 05-07-2023 01:26 PM
Originally Posted by boyt911sc (Post 11992736)
086/908 is the cast #, right above the cast # are the last 3 digits (stamped). Use a wire brush to clean the surface area and read the numbers (0 483 140 XYZ). Keep us posted. Thanks.
Tony
Looks like 033.
http://forums.pelicanparts.com/uploa...1683491123.jpg
boyt911sc 05-07-2023 02:37 PM
Wrong Warm-up Regulator………..
Originally Posted by maverck (Post 11993026)
Maverck,
If your car is an ‘81 SC US spec with lambda/OXS, the correct WUR is -090. The WUR-033 will not prevent it from RUNNING but will NEVER make it run well. I could lend you a WUR-090 that you could test on your car without any obligation to purchase. You could send it back to me if you are NOT fully satisfied. No question asked.
I have provided hundreds of these WUR’s to fellow Pelicanparts members with amazing success and counting. PM me if you are interested. Thanks.
Tony
PeteKz 05-07-2023 03:15 PM
Maverck: someone may have put in an 033 instead of the 090 when they disconnected the oxygen sensor. Maybe they were having problems with the OXS lambda system and decided to bypass it.
maverck 05-07-2023 03:36 PM
This community is awesome! Thank you so much.
Tony - you have a PM :)!
boyt911sc 06-30-2023 06:44 AM
Wur-090…….
Brian,
The WUR-090 that I sent to you will WORK, provided you have the the enrichment components for the lambda system all good and working. Check the following:
  • OXS
  • FV
  • Frequency valve relay.
  • 15° throttle switch.
  • 15°C and 35°C Temperature Switches.
  • ECU
  • Etc.
The WUR-033 you have now will not prevent the engine from starting but will NEVER run well. Where is the rubber hose from the side of the WUR-033 connected to? A picture would be helpful. Thanks.
Tony
Cevan 06-30-2023 07:45 AM
I have an '86. Can you explain why you prefer not to have the sensor plugged in?
pmax 06-30-2023 11:41 AM
Ivan
Not just for CA.
The lambda system makes the engine run better in "cruise" mode, for lack of a better word, and longer due to improved fueling with a closed loop feedback control system which is disabled by the throttle switch when the lead foot is applied.
