Carrera brake lights coming on too late!
A buddy's Carrera's brake pedal has to be depressed quite firmly to activate the brake light switch. During normal braking, the lights don't even come on. The switches and master cylinder are brand new, but no difference. Anyone else have this problem?
thanks
Mike 03 996tt w/efr7163 89 Carerra 3.6 |
Mike,
I'm having the same problem with my 87.. I was going to change the switches tomorrow, but I guess I'll wait and see the responses from the experts before I start.
Bob S 1984 930S Silver 1996 993 Polar Silver (Sold) 1987 911 Guards Red ( Gone but not forgotten) |
Banned but not out, yet..
don't know if the 80's cars use the same switch as the early cars, but on mine, the adjustment was quite easy. pull the carpet back near the pedals, remove the panel behind the pedals (mine is wood). you will see the culprit where the brake lever contacts a progressive switch. I pulled the thing out and took it apart to see how it worked. All I believe you have to do is adjust an out side nut which controlls when contact is made. You may want to take yours apart, it's quite easy, and figure out how to adjust. It was trial and error to find the perfect setting but now they work as they should. Sorry I don[t have the exact details but it was about 10 years a go.
An air cooled refrigerator. ‘Mein Teil’ |
I'm pretty sure the newer 911s (post ~75?) have the switch on the master cylinder, not in the pedal cluster. I know my SC is like that.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
Did you use OEM or aftermarket switches? Maybe you should try whichever one you didn't use.
1984 Targa |
I replaced both my switches in my 86 about 6 months ago. I was suffering the same problem and only got marginal improvement from the change. I think the pressure is set too high in the factory switches.
David Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module 997 C4 Cabriolet - Basalt Black 86 Turbo Body 911 Cab - Many Mods Gone and Missed: 97 993TT: PSS9, CarGraphic Exhaust |
I've had this problem on my 87. I replaced both switches on the MC and problem went away. I don't know what else it could be besides the switches.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Had same problem last year - replaced both switches and all is good. That seems to be the only solution on the later cars - the switches jrequire more pressure as the wear out.
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
Replacing both switches in my car fixed the same problem too.
Ron '88 Coupe (formerly) |
Add me to the list. I replaced both switches on my '87 and all is well.
Matthew |
both switches are on the MC?
1984 911 Euro Cabriolet 1988 928 S4 with Murf Supercharger S1 |
Yep, I just did this job myself a couple of weeks ago. Two pressure switches on the master cyl. Kind of a pain to get to, but not too bad. I ended up sitting indian style on the spare/smugglers box to do the job.
Hey guys, thanks for the replies. The lights came on too late before the switches were changed, and are the same now. The whole master cylinder was changed and it came with the switches. the MC was changed two weeks ago, so it is not from wear.
Maybe Porsche engineers like it when the drivers follwing a Porsche on the track say, " He didn't even press the brakes in that corner!"
