Dash indictor lights 83 sc
This is very recent but occasionally both direction indicator lights (arrows) will light up but not flash. Then they turn off just as abruptly as they turned on.
Any ideas what might cause this? Thx Hugh |
usually bad ground....or connection to one light bulb in the either front or rear tail light unit
Ivan also possibly the turn signal relay
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Thanks Ivan, that'll be good reason and opportunity to check connections and even give them a dab of dielectric grease.
Having said that, would such a questionable connection cause the lights to come on automatically? |
Heck, I’m only 5 not 71!
The below two threads can provide some help on why the tach turn signal lights start to act up in different ways.
https://forums.pelicanparts.com/porsche-911-technical-forum/819548-flasher-hazard-mods-my-80sc.html?highlight=Turn+signal https://forums.pelicanparts.com/porsche-911-technical-forum/850904-911-turn-signal-indicator-issue.html?highlight=Turn+signals
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
Thank you Pat. I'll check those sites to see what I can learn.
I don't feel comfortable attempting to mess with the innards of the relay. I'll re read your post to see if there's another way to attempt a solution. Meanwhile I'll live with it (obviously). Thank you, Hugh |
As mentioned above, I dared not mess with the flasher relay but instead decided to follow up on Ivan's suggestion.
I looked at the driver's front signal light first and lo and behold that was the bad one. Both the light bulb and the socket had some corrosion which I was able to clean off. Haven't had a problem since. Thx Ivan. |
Thanks for the repair follow up.
u r welcome
