Project Karl - noisy 915 on first drive :-(
Hey all,
Our 84 911 outlaw hit the road for the first time the other day. It was absolutely incredible for it to leave the driveway. Everything seems to be working great, except we have a strange, grinding / rattling noise in 1-4 gears and neutral when rolling forward. 5th is totally fine. The car has an LSD from wavetrac and numeric shifter along with wevo side plate and wevo gate shift. The transmission was rebuilt. In hindsight, he came highly recommended but I don’t know how experienced he was with 915 / diff set up. When moving forward, the only way I can get the noise to stop is to push the gear lever all the way to the right or to shift into 5th. It does not change pitch at all based on the speed of the car. It is consistent at all speeds and all gears as long as the car is rolling forward. If I am rolling in neutral with the engine running, the sound is the same. If I turn the engine off and continue to roll in neutral, the sound goes away. It does not seem to affect the drivability of the car. I have only driven it a few miles. But the car seems to drive fabulously. Here is a YouTube vid of the sound. https://youtube.com/shorts/-0695k-QuGA?feature=share I guess it could be a shifter adjustment or something far more complicated. We are so close to having this car on the road! Your help is appreciated. Here’s a pic of Karl on public roads for the first time! http://forums.pelicanparts.com/uploa...1683999193.jpg |
That is one nasty---in a beautiful way---looking Porsche Sean. Looks black but I know photos can be misleading. If it is and the wheels are black... work of art. Something about a flared 911 with no tail...Unordinary. The 5th gear thing, I'd be looking at shifter linkage beginning to end. Sound fits the look---nice growl.
Can you feel the rattle in the shift lever?
Are you using "Sport", semi-solid, or solid engine/trans mounts ?
It’s Irish green with brushed bronze wheels. Time to figure out the transmission and let this thing sing!!! |
Sounds like another thread here recently. I suggested maybe the 5th/reverse shift sleeve was adjusted too close to the reverse idler and was rubbing teeth. It was apart, so...
I really don’t want to pull the drivetrain but I think that’s where we are headed with this :-( Anyone else have insight? |
Sounds to me like something is touching the exhaust tubing or maybe a heat shield somewhere. Sound change in a left or right turn?
I would do a lot more looking before dropping the drivetrain. |
Karl seems to pull pretty good, to me it doesn't sound like
You have to drop the trans. Did you check your clips for the Throttle rod? Sounds like it's rattling under the tunnel. Good luck. |
Do you have a two post lift? Is the sound still there with no weight on the suspension?
Anyway wish you the best. |
| All times are GMT -8. The time now is 07:56 PM. |
