Using Obenauf's Oil on Already Cracked Seats?
Anyone have experience? I had a cracked chair that I tried to bring back, and as soon as the fibers got wet, they all tore along the pre-existing cracks. Don't want to make the seats worse than they already are.
Thanks.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
AutoBahned
dunno re that product or your... uh cracks, but some products will make smaller cracks seem to vanish
you could not wt. the seat for a while after tmt., or figure the cracks will let go sooner or later anyway I wonder how many people clicked thinking it was about cracked valve seats.... |
I use Obenauf on the seats in my 911. It is an excellent product to condition the leather, but I doubt it will help much with your cracks. I do not know of any leather conditioner that will repair cracks.
You may want to look at recovering the cracked areas of your seats. Good luck. ![]() ![]()
Bruce '12 Carrera S DFI '84 911 Carrera |
I only use Obenaufs. It will help soften up the fabric to reduce further cracking but will not do anything for existing cracks
Ole Skool - wouldn't have it any other way |
It's an excellent preventative and restorer of finish, but it won't fix cracks. It mutes their appearance but won't eliminate them.
Are you sure the cracks are in the leather itself, or just in the surface dye? I had a 928GT that the seats had been dyed so many times it looked like paint, and had cracked creases. I used a solvent to strip the seats down to the raw leather and they were actually okay underneath. I did a lot of conditioning on the leather and used Leatherique dye to refinish them. They actually turned out quite good.
2018 Porsche 911 GT3 manual 1984 Porsche 911 Carrera Targa 2021 Porsche Macan GTS 2018 BMW R1200GS Adventure Rallye 2020 Ducati Scrambler 1100 Sport Pro |
Gordon... Once leather fibers loose their natural adhesion to each other, no oil or cream is going to restore that adhesion. As you know, adding a liquid (or cream) makes matters worse by helping the fibers detach from one another. A way to prevent cracks from probagating is to gel epoxy a leather patch on that's longer than the existing crack. Patching doesn't look good but then neither does a cracking seat.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
i used this to recondition, restore and then redyed my seats. it makes the leather softer then u can use their crack repair then repeat the conditioning. It's good stuff, just bought another bottle of the oil rejuvenator and cleaner.
Home Page | Leatherique Restoration Products
Lost 2.7l engine #6141641, drop me a line if you find it. ![]()
what should I do with my seats, any recommendations? Just acquired an '84 3.2 and has a very nice champagne and black leather interior. Here are the seats... should I do anything to them (clean/condition)? leather doesn't feel dry and seats still feel pretty comfortable but obviously has some significant cracking...
TBD Prior: '84 911 3.2 Carrera, '83 911SC Targa IG: @heuersandcarreras "I want to use it. That's what 911s are for." - Richard Hammond Last edited by Matthew_VA; 05-13-2023 at 05:23 AM.. |
Obenaufs is junk. Just another claimed 'miracle in a botttle' that isn't. Save your money.
PCA Member since 1988
+1 on Leatherique.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
