1979 911SC CIS expansion tank
I’m reassembling my ‘79 SC after respray. Is the CIS expansion tank necessary for proper CIS operation? Emissions gear was removed a long time ago. Also running SSIs and sport muffler. Thank you in advance.
Old 05-24-2023, 08:33 AM
Banned
You mean the charcoal canister in the engine bay or the expansion tank in the front left wheel well?
Old 05-24-2023, 10:18 AM
Expansion tank in the left front fender.
Old 05-24-2023, 10:19 AM
Banned
You'd still need to vent the tank outside the car but I don't think you "need" it. It's a good idea to keep it, though, if you'd like to park your car in a garage without it reeking of gasoline.
Old 05-24-2023, 10:31 AM
HarryD's Avatar
This post by the late Grady Clay (who had encyclopedic knowledge of the 911) may be helpful:
https://forums.pelicanparts.com/porsche-911-technical-forum/1133548-fuel-expansion-hose-venting.html
Originally Posted by Grady Clay View Post
tref,
In the third diagram I posted above (labeled “05” is an
exploded parts diagram) the hoses from the rear of the
tunnel to the fan shroud and air filter assembly are
#22 and #23. In the trunk and to the front of the
tunnel (by the steering rack) are hoses #20 and #21.
Not labeled with a number are two plastic pipes in the
tunnel. Hoses #20 & #23 are 5 and hoses #21
& #22 are 6, including the un-labeled plastic pipes
in the tunnel.
Philippe, here are the later versions, starting in ’74.
Is the plastic vent pipe original in your RS?
1974 to 1977.
© Dr. Ing. h.c. F. Porsche A.G.
1 – Fuel tank
2 – Expansion chamber
3 – Activated charcoal filter
4 – Cooling fan upper shroud with hose connector
5 – Hose from cooling fan to activated charcoal filter
6 – Hose from activated charcoal filter to engine air filter
7 – Engine air filter
8 – Return hose connecting fuel tank with expansion chamber
1978 and later.
Some features to note:
The Expansion chamber hose to the fuel tank is at the
bottom of the chamber. This returns any liquid fuel to
the fuel tank during cool-off. Ideally this hose should
be continously down hill to the fuel tank. The vapor
only hose to the Activated charcoal filter is at the top
of the Expansion chamber with baffles.
While the ’78-> system is slightly simpler, the ’74-’77
system won’t give sudden surges of vapor to the
engine intake.
The ’69-’73 system had plastic hoses in the trunk. Over
time, temperature and fuel vapor, they shrink. I think
they all should be replaced with the braided fabric over
rubber hoses. These were not originally equipped with
hose clamps. Every connection should have the Norma-
Schellen (NS) clamps. Fuel vapors in the trunk can lead
to disaster. The little expansion tank under the cowel (1
in the early diagrams) can split a seal from age. That
should be inspected also.
Even race cars should have a proper vent system that
includes an expansion tank.
Best,
Grady
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-24-2023, 10:37 AM
Ok. The expansion tank stays! Thank you for the quick replies!
Old 05-24-2023, 10:48 AM
