what gauge steel to use for rear shock tower bracing
I am going to fabricate my own rear shock tower bracing since the elephant racing ones seem a bit over priced. Does anyone know what gauge steel should be used in this application? They will be similar to the EP ones in shape. thanks
Old 06-02-2023, 11:38 AM
For $170 I’d just buy the kit unless you have the tools,skill,time and metal laying around. Some use 16 gauge for weight, folded and or dimpled for strength. Others use 1/8 plate 11 gauge I believe? for the tower gussets. Really depends on how strong your metal brake is and what other tools are at your disposal. Obviously the the thicker the metal the harder it is to work and the heavier it is.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 06-03-2023, 06:50 AM
Yup, 16 ga if it's going to be U-shaped, 11 ga if a simple piece. I think you can get the kits cheaper, ~$80 or so.
The original RSR's also added patches to where the "crossmember" meets the "frame rail," as they also tend to crack there. And another patch underneath. There should be pics here somewhere of an original RSR car showing what the factory did.
Old 06-03-2023, 09:52 AM
I appreciate the help. 11g is about what I was thinking. You are correct on the cost vs time issue, but I do enjoy the fabrication part of the build. I don't have the talent or facility for most fabrication, but I like doing what I can.
Old 06-03-2023, 01:05 PM
PCA Member since 1988
IMEO, it makes little sense to use 11ga plate and weld it to 18ga sheet metal of the crossmember or longitudinals. 18ga bent into a U channel will do a better job. If you use something that thick, make sure you spread out the loads at those points. Otherwise, if you really drive the car hard on a track, you will end up with cracking at those points.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-03-2023, 01:43 PM
You have to do the welding anyway so it why spend $170. Takes 5 bucks in scrap metal. 1/8 plate
Old 06-03-2023, 01:49 PM
Here's where the factory reinforced the tubs on the RSR's. These are also important because they'll rip out or crack if something isn't done when subjected to racing. Adding these patches, along with the shock tower gussets will help eliminate any "surprises."
Old 06-04-2023, 07:33 AM
I agree, I just told him what I’ve seen done. Lighter metal stiffened with dimple dies or bead roller is what I would do.
Old 06-04-2023, 01:33 PM
All good points. I cannot seem to find what gauge steel ER uses on their braces.
Old 06-05-2023, 05:42 AM
Cory M's Avatar
It's more about time than material cost. It takes some time to make a template and grind to align well with the shock towers.
Weld the tops on the shock towers while you are at it. They are just spot welded and can be compromised with the added loads from coilovers.
Old 06-05-2023, 07:10 AM
